Alot of help needed
  • b2b
    • Jun 2015
    • 10
    • Chandler AZ
    Floats adjusted, choke bb and springs installed
    I benched sync using a twist tie
    Carbs installed and bike is idling at 2500
    Now i have a petcock leaking
    Is it possible to rebuild it while still on tank?
    79 F
    • MPittma100
      • Aug 2011
      • 2359
      You are making progress. Need to sync carbs while running with sync tool. Keep fan in front of engine while adjusting. Out of sync is likely why the high idle is present.
      Cannot sync carbs while tank is on. You will need to have a remote fuel source hooked up to carbs or get some long fuel lines and use the tank.
      Would not advise rebuilding petcocks while still on tank. The diaphragm o-ring seat in the petcocks should be polished for proper seating. Need to rebuild both petcocks.
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
      • b2b
        • Jun 2015
        • 10
        • Chandler AZ
        Bike is up and running.
        Thank you Tarzan for all the help.
        79 F
        • tarzan
          • 1700
          • Chandler,Az.
          I'm glad I could help Paul. You should post a pic of your bike here so everyone can enjoy it. It's a nice one.
          80 SG XS1100
          14 Victory Cross Country
