I was going to get my XJ inspected yesterday when I noticed the "headlight" warning is lit up on the dash. Seems I only have low beam, when switching to high beam the low beam stays on. I first thought it must be the sealed 7" headlight so I ran to NAPA and bought another for $10, still have the same issue. So I took the light I thought was bad and plugged it into my other XJ and found it works perfectly.
Here are the voltage readings -- At the headlight connection, the bike with the working light shows 11.4v on the low beam wire and 4.5v on the high beam with the switch on low beam. When I put the switch on high beam, I get 4.5v on the low beam wire and 11.5v on the high beam wire. The bike with issues shows 11.5v on both the high and low beam wires regardless of what position the switch is in. The other thing I noticed with the problem bike is that the headlight doesn't come on immediately when I turn the key to "on" like it should, it takes a second or two to fully light up.
Can somebody smarter than me help me figure this out please? Thanks - Billy
