carbs
  • Dave_S
    • Jul 2015
    • 12
    • Rothbury, England
    carbs
    Are there any mods/changes require to fit carbs from 1979 XS1100SE to 1978 XS1100?
    XS11
    If you mean a 1979 SF Special to a 1978 E, nope, nothing needs to be changed if the carburetors are still stock and they haven't been monkeyed with.
    • Dave_S
      • Jul 2015
      • 12
      • Rothbury, England
      carbs
      Thanks for your reply, the carbs were advertised as 79SF but using Crazy Steve's Carb Identifier they are 80-82, any changes (in addition to jets) to fit them on a 78?
      XS11
      • mack
        • 2411
        • Ontario, Canada
        not really
        jets and metering follow the carb body, not the motor. The only thing to really watch for is that the vents in the upper air box need to be drillied out if you are using 78/79 carbs and 80/81 air box. Of course this is moot if you have pods. Geez missed the SF to an E part, no problems as Scottt said!
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
        • Dave_S
          • Jul 2015
          • 12
          • Rothbury, England
          carbs
          standard airbox - so no mods required - correct?
          XS11
            Correct. The later carbs only have 2 "T"s, for the fuel. Earlier carbs have 4 "T"s, two above the fuel "T"s are for bowl vent. They plug into the airbox, so if you have the old style aitbox, you SHOULD cap the two plastic nipples on top to keep the dirt out of the engine.
            Other than that, I've swapped carbs back and forth between years with no problems. As Mac said, carbs need to be jetted for the year of the carb body, and not the engine.
              I put a set of stock '80G carburetors on a 1978E (Planedick's Pathfinder ) and they worked perfectly.
              There were no problems and we plugged the float bowl vent holes in the airbox too.
              • Dave_S
                • Jul 2015
                • 12
                • Rothbury, England
                Carbs
                thanks for the info guys, hopefully the old girl will be back on the road soon, just need some summer weather to enjoy, ah we have summer weather - it's tonking it down!
                XS11
                  Well, work on it in the dry, and dash out when it stops! I've been to the UK in November, so I know how it can get.....
                  • Dave_S
                    • Jul 2015
                    • 12
                    • Rothbury, England
                    Carbs
                    Having established that the carbs are from 80/82 model, I’m now looking at the fuel pipes. From DiverRay’s reply:
                    “The later carbs only have 2 "T"s, for the fuel. Earlier carbs have 4 "T"s, two above the fuel "T"s are for bowl vent”
                    The fuel pipes attached to the carbs have 4 “T”s, I have photos but can’t figure out how to attach without using an URL which I don't have. Please drop me a line @ joesoap126@hotmail.com for the pics if you can advise on this one. Cheers Dave
                    XS11
