Endless squeaky brakes
  • 1887
    • 91
    • Ottawa, Ontario, Canada
    I have a 1980 Standard, I completely rebuilt the front brakes (new master cylinder kit, new brake lines, new pistons & seals, everything thoroughly cleaned), I did not replace the pads because they had tons of life left. I cleaned them with brake clean, I also cleaned the ss pad slider surfaces. I used brake grease on the back of the pads, put er all back together and it was a thing of beauty - brakes were perfect...until...A week later it started to squeak during low pressure stops - it would go away if I got on the brakes harder. So, I took er all apart , cleaned off the brake lube, sprayed the pads, reapplied brake grease (a bit more this time) and it was fine....for a week. The squeak came back.
    I only put grease on where the back of the pads touch the piston & caliper claw. Am I doing something wrong? It is annoying and my dog is starting to hate me.
    1980 G
    Jardine Spaghetti
    http://s1337.photobucket.com/user/Ug...ish/slideshow/
  • 1887
    • 91
    I should add: The pads that are currently on the bike are SBS however I am unaware of the model (organic or sintered). Could this be a factor?
    1980 G
    Jardine Spaghetti
    • DAVINCI
      • Jan 2011
      • 1048
      • Cedar Mountain, NC
      Chamfer the leading edge of each pad with a file, it worked for me.
      • 1887
        • 91
        actually i already did that because the edges had a bit of scaling/flaking
        1980 G
        Jardine Spaghetti
        • BowlingSS
          • Apr 2015
          • 398
          • Lawrenceville, GA.
          I would replace the pads.
          Bill
            If the pads don't already have one, cut a slot in each with a hacksaw. Don't go full depth, put it in the middle of the pad top-to-bottom. The OEM pads have this slot. You can also try a scotchbrite pad on the rotor surface to 'break' the glaze.
            But some pads will squeak because of the material....
            • 1887
              • 91
              The pads already have a slot in them (top to bottom), should I put another slot in?
              1980 G
              Jardine Spaghetti
                • 8930
                +1 this has worked for me too except I used a grinding wheel, much faster.
                • DAVINCI
                  • Jan 2011
                  • 1048
                  @ 1887:
                  No, not a slot, a chamfer. At the leading edge, (lowest as the pads are installed) file an angle on the pad material
                  • MPittma100
                    • Aug 2011
                    • 2359
                    Brake Quiet
                    An item sold in auto parts store - should stop the noise. It is red in color. Comes in liquid or spray application. Cheap fix. Apply to back of pads, let dry, reinstall pads.
                    1981 XS1100H Venturer
                    K&N Air Filter
                    ACCT
                    Custom Paint by Deitz
                    Geezer Rectifier/Regulator
                    Stebel Nautilus Horn
                    EBC Front Rotors
                    Limie Accent Moves On In 2015
                    Mike
                    • 1887
                      • 91
                      I beveled the edges of the pads last night with a bench grinder. I smeared "disc quiet" on the back of the pads, let it sit and reassembled them. I haven't ridden it yet, I will be going for a ride tonight to test it.
                      1980 G
                      Jardine Spaghetti
                      • 1887
                        • 91
                        Squeak is gone! Hooray
                        1980 G
                        Jardine Spaghetti
                        • BowlingSS
                          • Apr 2015
                          • 398
                          Hope it stays gone.
                          Bill
                          • 1887
                            • 91
                            ARGH - the damn squeak came back? That high pitch noise is driving me nuts, I find myself not using any light application of the brakes to avoid that trailer trash sound. I slam on the brakes at the last minute; no more trail braking!
                            1980 G
                            Jardine Spaghetti
                              • 8930
                              Might have to scuff the glaze off the rotors with some 80 grit, easy to do with the rotors off the bike, not so easy otherwise.
