Endless squeaky brakes
    • 7941
    If you're running sintered pads, get something else. There are a bunch of options for that bike.
      • 7941
      Might have to scuff the glaze off the rotors with some 80 grit, easy to do with the rotors off the bike, not so easy otherwise.
      Yep. Use garnet paper.
      • 1887
        • 91
        • Ottawa, Ontario, Canada
        I am going to buy some organic pads and sand the rotors. It will take a week or so to get the pads so I will have to listen to the squeak for a week.
        1980 G
        Jardine Spaghetti
        http://s1337.photobucket.com/user/Ug...ish/slideshow/
          • 3189
          Check for a bent rotor! That will make a squeak in a hurry. Also check the spooge hole is not partly plugged off.
          • 1887
            • 91
            Sponge hole is good, no pulsating during braking either so I don't think there's any runout on the rotors. I ordered a new set of organic EBC pads, I will resurface the rotors with 80 grit and install them with some disk quiet.
            1980 G
            Jardine Spaghetti
