Is a 80 and 79 Ignition Box the same??
  • BowlingSS
    • Apr 2015
    • 398
    • Lawrenceville, GA.
    Is a 79 Special Ignition Box the same as a 80 SG? It looks different inside.
    Thanks.
    Bill
    They're functionally the same. There are some internal differences as Yamaha made changes to the design over the course of production but hook-up and operation is the same. The '81 ignition is a one-year-only as is the '82. The '78-80 boxes all interchange.
    • BowlingSS
      • Apr 2015
      • 398
      Thanks. My wife (engineering tech) cleaned up the PCB and it looks a lot better. I put it back on. It still looses a cylinder or two. It looks like it is a pickup coil. I did not think it was this because someone already replaced the wires. With the engine running I barley touched the wires and the engine died.
      It looks like the connection have come loose.
      I wife said she would replace the wires if I remove the coil. Do you really have to drill the screws out and replace them with special bolts and have a special tool like the manual says. I would also like to clean up the advance.
      Thanks everyone.
      Bill
        Hey, Bill,
        Yes, you have to drill out the special bolts but they are no longer available from Yamaha so you can legally replace them with regular bolts and it will pass any kind of inspection.
        If you're going to repair the pick-up coil wires but they're too short, find a piece of almost any kind of wire and splice it inside the harness down by the Neutral switch. That way you only have one repair splice in the O.E.M. pick-up coil wires and the double splice is safely tucked away in the harness right next to the exhaust pipe. .
        โ™ฌ
        โ™ฌ
        • BowlingSS
          • Apr 2015
          • 398
          Originally posted by 3Phase
          Hey, Bill,
          That is a great idea.
          Thanks.
          Bill
            While you have the harness open, put a small piece of that self-amalgamating tape on all of the splices.
            That'll help keep any water that gets into the sheath from shorting the pick-ups to the Neutral Switch wire or to each other and killing the engine when you wash the bike or ride through a puddle.
            โ™ฌ
            โ™ฌ
            • SFerinTEXAS
              • Jun 2006
              • 876
              Can I get 1st dibes on her if something happens to you? LOL
              79SF
              XJ11
              78E
                • 3917
                Lmfaoooo. That was funny!
                • BowlingSS
                  • Apr 2015
                  • 398
                  My wife fixed my running problems. The pickup coil wires have been repaired a couple of time. There were a few breaks in the wires. My wife replaced both wires (with silicone test leads) and now it runs great. I also bought a new maint. free battery off of Amazon.
                  Now after I take it for a few rides I need to work on the rest of my list.
                  Thanks for everyone's help.
                  Bill
                    • 7775
                    Bill,
                    Will you be bringing your wife to XS Southeast? We should have 20 to 30 XS1100's there. We could keep her very busy. She'll have a lot of new friends!
                    • BowlingSS
                      • Apr 2015
                      • 398
                      Bill,
                      What does it pay?? HaHa
                      I will tell her what you said. She likes doing this kind of stuff.
                      Bill
                        • 7775
                        Bill
                        With this bunch, I promise it doesn't pay much!
                          Beer two at most
