Gas consumption is way too HIGH, Mileage too low
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    #136
    The only difference there may be is the pilot to main hole may or may not be there on an 80 carb.
    I showed you what that looked like on the carbs i lent you.
    Oh, of course the bowls are different too, but you can swap on yours.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    • justinc1081
      • Apr 2013
      • 61
      • Springfield, MO
      #137
      I thought so but I'll leave the answer to one of the more senior xs'ers
      80 SG
      • RichV
        • May 2013
        • 374
        • Everywhere
        #138
        Today I rode the bike for a full tank (to reserve).
        The Bike got 38 MPG and this is what the plugs looked like. They are left to right, 1-4. #2 is the newest plug.
        _________________________________________
        1981 XS1100SH (Lola) - Bright Cardinal Red
        Whatever Lola wants, Lola gets.. Don't mess with Lola.
        Mostly stock with a few minor upgrades
        1981 XS11000SH being used for parts (Sold off)
        Also have:
        2009 Harley Davidson FLSTC with over 120K miles. All mine.
        Currently traveling the country with an aluminum can in tow and a motorcycle in the truck bed in search of the perfect road.
        • MPittma100
          • Aug 2011
          • 2359
          Convert
          Originally posted by RichV
          Is it okay to mix 80 carbs with 81? I know there are some differences but does it matter? Can you "convert" and 80 to and 81?
          Yes they will interchange. Go through the used one that you get and transfer your new parts to it. Clean it and verify all passages are clear. Adjust floats. Be careful of the balls and springs for the choke rod detents as they know how to disappear when taken apart. Reinstall and sync again.
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
          • justinc1081
            • Apr 2013
            • 61
            • Springfield, MO
            #140
            Those plugs look really good and 38 mpg is great!
            I looked at my spare carb bodies and did not find a #2, only to realize that my set has 2 - #2's so #1 and #2 are actually the #2 body, had to modify one of them due to a broken post situation.
            The other spares have screws that need to be drilled out for the mixture screw or pilot screw and of course 1 has a broken float post
            80 SG
            • MPittma100
              • Aug 2011
              • 2359
              Success!
              All 95 horses ready to be fed! Congratulations! Plugs are beginning to color properly. I'm sure you enjoyed this ride a lot more than the previous ones. Bring your number 2 bad carburetor to the XSSE rally and let's have a look-see.
              K&N Air Filter
              ACCT
              EBC Front Rotors
              Mike
              • RichV
                • May 2013
                • 374
                • Everywhere
                #142
                I also have a #2 with a broken float post. I guess I'll try to fix it at some point. Not now though. Time to ride.
                As a side note, my right muffler weld broke the other day. It's why it was hanging funny. This is one of those time I'm glad I have a welder.
                Also have:
                • RichV
                  • May 2013
                  • 374
                  • Everywhere
                  #143
                  If I can fit it, I'll bring the whole rack.
                  At some point I need to test them again. I did fiddle with it and that has been know to bring about spontaneous healing... or it can be worse. Both are likely outcomes.
                  Also have:
