Scraping - bottoming out
  • 1887
    • 91
    • Ottawa, Ontario, Canada
    So, I put some new skins on: Shinko 712's what a difference over those old Dunlop 404's, literally night and day. Now I can push it harder in the corners but I noticed that it bottoms out, there is a scrapping sound, especially in right hand leaners. My rear suspension is set at the second firmest setting and it pogos when I am pushing it (zero rebound dampening). Can these shocks be rebuilt? I am looking for a cost effective solution. Thanks
    1980 G
    Jardine Spaghetti
    http://s1337.photobucket.com/user/Ug...ish/slideshow/
    Hey 1887,
    The OEM shocks can't be rebuilt...and they NEVER had rebound dampening anyways! SO....you'll want to look into getting some other shocks..... many here recommend the XJ shocks which ARE rebuildable, and are air assisted as well. I do not know if they have rebound dampening though?? But almost all modern shocks will have both compression and expansion dampening. Folks have had decent experience with even just the cheap ones you can get from Partsnmore.com or Mikesxs.net vs. putting $400 into some bigger brands.
    • 1887
      • 91
      All shocks have rebound dampening (except possible mine, haha).
      1980 G
      Jardine Spaghetti
        Are you sure they are stock length shocks? Some PO may have swapped them out for shorter ones so he could look cool.
        • 1887
          • 91
          good point, I don't know if they a stock length. They look stock to me, I guess I'll have to measure them, what length should they be? Center of eyelet to center of eyelet on the center stand (that's a lot of centers).
          1980 G
          Jardine Spaghetti
            12.5".................
              The stock shocks are actually 12 5/8" (yeah, it's only 1/8"... LOL) and weren't that good when new. But these bikes didn't handle all that well when new if you pushed them hard....
              • 1887
                • 91
                Just measured them, center to center they are 12 5/8".
                1980 G
                Jardine Spaghetti
                • 1887
                  • 91
                  The shocks look 100% stock to me. Maybe the spring has weakened over time or these bikes just bottom out easily? Can I replace this with any 12.5" shock? Maybe I can track down some used Progressive 412's or 430's.
                  1980 G
                  Jardine Spaghetti
                  • WMarshy
                    • Apr 2009
                    • 2402
                    • Mexico NY
                    I find my center stand will touch down when I hit a bump in a hard corner. Pegs will drag first usually.
                    '79 XS11 F
                    Stock except K&N
                    '79 XS11 SF
                    Stock, no title.
                    '84 Chevy K-10 "Big Blue"
                    • mjpxs11sh
                      • Jan 2011
                      • 299
                      • N/E, Illinois
                      id be extremely careful going around corners too fast with the shaft drive. the rear wheel will kick out on you. my footpegs also bottom out when im too low around the corners too givin me a warning lol
                      Max
                      81 XS1100SH Black Beast Mutt
                      Kerker 4/1
                      stock carbs and air box.
                      78 headlite, handle bars,
                      1 set of ea-160/85mph guages,
                      crash bars, cruise control
                      Other 2 Wheelers
                      78 XS1100E jet kit, Kerker 4/1, air pods, jet kit-RIP
                      94 CBR1000F jet kit,Two Bros pipe, K&N Filter
                      • 1887
                        • 91
                        "id be extremely careful going around corners too fast with the shaft drive. the rear wheel will kick out on you" What do you mean kick out?
                        I don't plan on blazin the twisties with this old girl (its not just the back the sucks, the front end feels like twist ties), but I'd like to be able to ride at a spirited pace.
                        1980 G
                        Jardine Spaghetti
                        • WMarshy
                          • Apr 2009
                          • 2402
                          • Mexico NY
                          That's kind of a brash statement don't ya think? I've driven my bike hard into and out of many tight corners and have never had my tire kick out.
                          '79 XS11 F
                          Stock except K&N
                          '79 XS11 SF
                          Stock, no title.
                            I don't know about the shaft drive having anything to do with it but the centerstand foot lever doesn't fold up like the footpegs.
                            When it hits the ground in a left-hand turn it can't 'give' at all so it acts as a fulcrum. If the bike continues to lean, the rear wheel lifts up and the back end instantly slips to the right, "Boop! There it is!"
                            The only way I can think of for the shaft drive to make the rear wheel slip in a turn is if you were decelerating into a corner, then suddenly accelerated. The sudden "kick" from taking up the lash in the drive train can break the rear tire loose if you do it j-u-u-u-ust wrong but a chain drive can do the same thing.
                            • 1887
                              • 91
                              Smooth application of throttle is pretty much go fast 101, maybe a bit more so on a big ole shaftie. And I can deal with hitting the hard parts, center stand, exhaust pegs etc. I was just worried about rear wheel kicking out statement.
                              Its a fun bike to ride it reminds me of the '72 Buick I had with Dunlop Gold Seal bias tires.
                              1980 G
                              Jardine Spaghetti
