Hello all just joined like 10 minutes ago! I have been searching and searching with no results.
But here goes it's a 79 1100 with vin/serial as 3H4 000238 no mods, nothing extra, nothing terribly special besides I love riding this bike. When it was ridable
Ok so I am running into issues after I have completely rebuilt the mechanical side of this bike. Brakes, carbs, ignition systems, all the lubricants as well. My problem started out as ignition system failure fixed that. Now as the bike starts it revs up 5k rpm and stays there. Then as soon as I touch the throttle it sticks as high as the twist sets it. Now I have removed the carbs several times making sure nothing is sticking, and bench setting the butterfly to what many of the people and threads have said to adjust to. Throttle cable is loose and freely moving. The throttle adjustment screw is backed off to just touching the lever. All vacuum lines have been checked no cracks or stiff lines. Now while redoing the carbs I did not pay attention and did unscrew the fuel mixture screws on the front top area. Then realizing that they are set by factory. Have tried the adjustments previously stated in threads 1 1/4, 2, 2 1/2 and up to 3 turns out. The rebuild kits were fully installed except for the jets I didn't move or replace them. I did make sure floats and pins were moving freely, everything that was supposed to move, moved freely. Anything that wasn't was torqued where I could find specs for. I used the Haynes manual that I got with the bike. It covers almost nothing for carb issues at least what I am dealing with. I am waiting for a manometer, to sync the carbs but can't get the rpms down enough to even attempt it.
Any help is greatly appriciated I am trying to get my dad's bike running again!!!
When you install the screws, use a screw driver wit ha small diameter handle and LIGHTLY seat the screws, then turn out 1 1/2 turns to start with.
The Pilot JETs like the MAIN jets are accessed thru the bottom of the carb under the float bowl. The Pilot Jet/idle SCREW is the screw/spring assembly on the top front of the carb body.
