Regulator/ rectifier
  • hondakid11
    • Apr 2015
    • 39
    • Lockport, N.Y.
    so ive been having charging issues since i got the bike in january, and havent found the problem yet. until last night.. i pulled the reg.rec out and went to test it. the rec tested on 0/70 on all but one was 0/220.. but then i went to test the reg and found that my reg only had brown & green wires coming out of it.. but my plug on the bike has brown, green & black.
    im assuming this is why ive been having issues. am i correct in thinking this?
    my alt tested fine after i fixed the 3 white wire connectors.
    does anyone have the oem part number for this reg/rec??
    79 XS1100SF k&n pod filters
    emgo shorty mufflers (w/o baffles)
    chopped rear
    springer seat
    led turn signels
    led brake light
    side mount verticle plate
    drag bars.
    86 Suzuki Intruder VS700
    8" biltwell chumps
    chopped rear
    nasty twins drag pipes
  • hondakid11
    • Apr 2015
    • 39
    • Lockport, N.Y.
    all the ones online show only 2 wires.. but the service manual shows 3.
    and here are the test results
    a - 0/70
    b - 0/70
    c - 0/70
    d - 0/0
    e - 0/70
    f - 0/70
    g - 0/70
    h 0/220
    chopped rear
    springer seat
    led turn signels
    led brake light
    drag bars.
    8" biltwell chumps
    chopped rear
    • MPittma100
      • Aug 2011
      • 2359
      Answers
      A lot of questions have already been answered about the 11s here on the forum. It is a good idea to use the "search" feature to see if an answer is there. May save you some wait time.
      Look here:
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
        Although there is a black wire in the clip the ground is through the frame at the mounting location. Clean the paint and any filth under the mounting screws and then retest the charging system (above 1500 dons of course).
