Speedo gear housing
  • ekim
    • Jun 2013
    • 106
    Speedo gear housing
    I pulled the front wheel and took it down to have a new tire mounted.
    In trying to reinstall the wheel I noticed the notched area on the gear assembly has sheared off the corner.
    The notched area is held by the stub on the fork. This keeps the speedo gear housing from rotating on the axle etc.
    When I tighten the axle castle nut, the gear housing slips out the notch at the end of the fork. Things then become mis-aligned on the front axle.
    I have removed the calipers, fender, fork brace.
    The part I am referring to is:
    341-25190-01-00 (GEAR UNIT ASSY )
    Is there a way to fix what I have or do I need to find another gear housing ?
    Any and all advice appreciated!
    1980 XS1100 Standard (G)
    Original Owner
    Stock plus:
    2011 FJR1300
    1978 SR500
    Let me look at what I have. You need the one for the STANDARD, as the Special is different. I MAY be able to repair it if all else fails.
    • ekim
      • Jun 2013
      • 106
      Ray,
      If you have one that would be great.
      I am getting one from Andreas but it will take some time.
      I could replenish one from you once his arrives.
      The bike and owner are both making sad faces during this nice weather.
      Original Owner
      Stock plus:
      2011 FJR1300
      1978 SR500
