Jeffs rebuild lol
    Very nice work, Jeff! Right on!
      Doing great, but clearances a little off.
      Exhaust
      22 20 25 25
      Intake
      24 18 25 25
      Hey Jeff,
      Those valve clearances are a bit Loose for the intakes, at least # 1, 3, 4 even with the earlier looser specs.
      The old specs for the earlier machines were
      IN: 0.16mm - 0.20mm
      Later changed for the later engines a bit tighter:
      0.11mm - 0.15mm
      The Exhaust appear to be within the loose spec range, and we know they will tighten up with wear.
      As folks have stated, the dots appear to be in good alignment as long as the timing mark "T" mark is pointing at the pointer.
      • Jeffintampa
        • Apr 2011
        • 344
        • Zephyrhills, Florida
        Should I change some more shims or go for a while and check it again
        Bike History:1980 XS 1100 special current bike
        1980 XS 850 special wife sold
        • BowlingSS
          • Apr 2015
          • 398
          • Lawrenceville, GA.
          I would change the shims now but go to the loose end of the spec.
          Bill
          Jardine Spaghetti with Harley Mufflers
          • Jeffintampa
            • Apr 2011
            • 344
            Progress
            Well, I got the Oil pan and exhaust back on tonight, I put a new gasket on the oil pan and a thin coat of high temp gasket goop on both sides. The exhaust didn't fight me to much just kept everything real wiggly and loose till I had it all hooked up. A friend of mine brazed my muffler crack. I of course lost my O ring for my oil filter canister, so ordered a new filter, I am thinking of putting another coat of high temp gasket goop around the edge it always seems to leak lol.
            I think I am going to put oil in it and spin the motor with the starter for a few minutes and recheck my clearances on the valves before I go to pulling shims and replacing them again. I don't know how I didn't hit the mark but it is what it is.
            slow headway
              Great work, Jeff!
              You shouldn't need any goop. Are you talking about leaking from the edge of the oil pan or the oil filter housing?
              An oil filter leak is usually caused when someone loses the small o-ring from the filter bolt or when the large o-ring slips out of the groove in the housing while the filter bolt was being tightened.
              The first can be fixed by putting the o-ring on the bolt where it belongs.
              The second can be fixed putting the o-ring in the groove with a few dabs of grease to tack it in place, then holding the housing in place against the bottom of the engine so the o-ring can't pop out while you tighten the filter bolt.
              If it's the oil pan that's leaking, take your time and don't get in a hurry.
              • Jeffintampa
                • Apr 2011
                • 344
                Oil filter canister
                I put a small bead of gasket goop under the O ring, it seems it always drips around there
                  Cool, you really should try to figure out why the housing leaks and use a new o-ring when you change the oil filter but you can use goop until you figure out what's wrong. Be careful because if you use too much it can ooze into the housing.
                  Once it's inside the housing the goop will either be forced onto the oil filter and embed itself in the pleats where everything will be just fine or it will keep moving around until it's forced through the oil pressure bypass valve into the main oil gallery where everything will be not just fine.
                  • Jeffintampa
                    • Apr 2011
                    • 344
                    goop
                    I put a very small bead in the channel the big O ring goes in didn't get any to squish out the outside.
                    on Valves.
                    I spun it over probably 20 times and check my clearances on shims and they numbers have changed for sure. I am going to measure them all with my friend tomorrow and will post the readings
                    • Jeffintampa
                      • Apr 2011
                      • 344
                      well this deep
                      [QUOTE=Jeffintampa;467049]Well chain installed, the siming I did came out
                      Exhaust
                      22 20 25 25
                      Intake
                      24 18 25 25
                      Well, I measured everything again and pretty much have the same readings.
                      I think I will go 5 down on 1 3 5 might as well as I still have a bit of time till carbs come back.
                      Had 150 plus on compression on all 4
                      • Jeffintampa
                        • Apr 2011
                        • 344
                        yea progress
                        Intake
                        24 18 25 25 I put +5 shims in 1 3 4. They all came out between 20 and 18. Put a bead of goop around set the gasket in it, put the cover on (screw with clip is middle back correct?) Put the horns on, plugs in, wires on, filled the oil.
                        Think I am ready for carbs......Yea
