another day of swapping parts, cleaning etc, nuttin workn
Here is a list of things that I did today,,, I put the new iridium plug back in number four, put the old plug from four into number one for kicks, four is still not running and one is running good, I also polished the seat and checked the needle for grooving in three and four,, I also swapped the four seat and needle into three, and three into four,,,four is still not running and three is running good, I checked the pilot jet for four , cleaned it, and blew thru the passages with cleaner,, the vents are all clear,, cleaner blows thru them fine,, I ran it at 3500 rpm, but only about forty seconds since I ran it out of gas at that point, nevertheless, no heat from number four,,,re bench test for leaks anywhere,, no problem even when I pressured the fuel going into the bowls with everything I could blow into it,,, so here we are,, accomplished nothing so far,, about the only thing I did not do today that I wanted to was check the primary voltage on the coils,, I cant reach into the area ,, so I have to check the manual to see how to get in there. Anybody have any great ideas?
