Blinkers causing slight feedback into brake lights
  • Blinkers causing slight feedback into brake lights
    So when either blinker is on the brake lights slightly dim with each blink...where should I look?
    1979 F worst one i could find
    to convert into a bobber/ streetfighter!
    _________________________________
    We can't all get along!
    Hmmm.....
    If you're running at idle, I don't think that you have a problem.
    These alternators don't generate much current at idle so the battery has to make up the difference.
    My 1980 XS1100LG does it even with a new battery...but it's barely noticeable.
    Rev it up a bit and see if it goes away...
    Just a thought....
    Tenorman
    Bikes that I have owned and enjoyed...
    1964 Allstate 250
    1970 Yamaha DT1
    1959 Mobylette
    1970 Yamaha JT1
    1995 Suzuki 80
    1978 Yamaha XS650
    1980 Yamaha XS1100LG
    2005 BMW R1150R
      Interesting I'm only testing with the bike not running as I'm not ready to fire it up just yet....so maybe I should just move on till I can test it when running.
        Hey there,
        Yep, if you notice, the OEM fuse for the turn signals is 20 amps.....all of the other circuits are only 10 amps...that is a bit of a clue. SO...yep, just continue with your work....although some folks have have reported that with proper cleaning of the harness connections, their turn signals would work with just the key on, without the engine running. Some folks had problems getting their turn signals to work with just the key on. But because of the current draw of the OEM flasher unit, and the dual 27 watts filaments in the bulbs you're experiencing some 4.5 amps pulsing draw with just the bulbs, not to mention the current needed to heat up the flasher to actuate it.
          Thanks catman moving on
