So when either blinker is on the brake lights slightly dim with each blink...where should I look?
Blinkers causing slight feedback into brake lights
1979 F worst one i could find
to convert into a bobber/ streetfighter!
_________________________________
We can't all get along!Tags: None -
Hmmm.....
If you're running at idle, I don't think that you have a problem.
These alternators don't generate much current at idle so the battery has to make up the difference.
My 1980 XS1100LG does it even with a new battery...but it's barely noticeable.
Rev it up a bit and see if it goes away...
Just a thought....
TenormanBikes that I have owned and enjoyed...
1964 Allstate 250
1970 Yamaha DT1
1959 Mobylette
1970 Yamaha JT1
1995 Suzuki 80
1978 Yamaha XS650
1980 Yamaha XS1100LG
2005 BMW R1150R -
Interesting I'm only testing with the bike not running as I'm not ready to fire it up just yet....so maybe I should just move on till I can test it when running.1979 F worst one i could find
We can't all get along!Comment
Hey there,
Yep, if you notice, the OEM fuse for the turn signals is 20 amps.....all of the other circuits are only 10 amps...that is a bit of a clue.
SO...yep, just continue with your work....although some folks have have reported that with proper cleaning of the harness connections, their turn signals would work with just the key on, without the engine running. Some folks had problems getting their turn signals to work with just the key on. But because of the current draw of the OEM flasher unit, and the dual 27 watts filaments in the bulbs you're experiencing some 4.5 amps pulsing draw with just the bulbs, not to mention the current needed to heat up the flasher to actuate it.
T.C.T. C. Gresham
Thanks catman moving on1979 F worst one i could find
