Vacum draw
  • mack
    • 2411
    • Ontario, Canada
    Vacum draw
    has anyone ever put a guage on one of the carb boots with the motor running to see what the draw is on the intake cycle?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Sure, that's what you're doing when you do a carb sync. I'm seeing around 7-9 inches of mercury at idle after damping the vacuum signal so the gauge doesn't fluctuate too much. That's with my gauge, you may see something a bit different.
      Here at 4,800ft. elev. I get the normal 18in. of vacuum that's expected at this elevation, mercury manometer AND MorganCarbTune. Sea level vacuum readings SHOULD be at near the the 22in. range at idle, auto or bike, as they are both just an air pump. Substantually lower than normal, with elevation figured in indicates several things besides valves not tottally sealing. A weak ignition spark dropped mine on the Bentley to 14in.to get it 'dialed' in evenly across all four cyls......which I didn't catch for couple yrs.. It was a gradual loss of a good spark, and I just kept tuning to THAT every so often.
      Corrected with the common voltage drop areas on these ole'scoots, along with replacing gradual failing stock coils with VFR coils and new plug wires got vacuum reading back to where they're supposed to be at 18in. with mixtures and sync vacuums corrected.
        • 7737
        +1 on 22" with my 4 gauge set-up. At sea level.
          Me too. 20" to 22" like any other IC engine or something is wrong. Most of items on the common vacuum troubleshooting charts apply to motorcycles too.
            I can easily get 16+ inches here.
              • 9980
              Guages usually vary though unless they are calibrated.
                • 7737
                For the way we use them, just put in a "T" and set them all to the same port BEFORE starting a sync. If they are up or down a couple of inches, it doesn't matter, as they are all the same when you are done.
                  • 9980
                  Exactly Ray, I have a hand vacuum pump I use. Could care less about inches of vacuum, just as long as they are all the same.
                  • mack
                    • 2411
                    • Ontario, Canada
                    Vacum
                    I was rolling my E over by hand and put my palm over the intake. I was surprised at how strong the suction was. Didn't know exactly how much it was and was curious if anyone had a number thanx.
                    mack
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    613-398-6186
                      Well, gonna 'pick' on ya' Nate. If the idle doesn't get you more than that at your location(should be about 20in.), there's an issue going on......BTDT. My bet is also, IIRC your bike having the later carbs(see yours has the earlier ones), if idle mixture screws are out that 3 1/2+ range(NEVER more than 2 1/2 out, even on the later carbs), the chances of a weak spark from coils, or prim. voltage TO coils being low IS fairly high.....BTDT also. Seem to remember you having installed Geezer's reg. also, but can't remember for sure. As you know, that's no guarentee that 13v exist at prim. side of coils at idle. Just for G/G you MAY wanna check that, key on should be same,same as batt. voltage with key on. If not, you know the fix routine. Whatever the case may be, your vacuum readings are what they are up here if I go up to 9-10,000ft. 16in. is maximan a vacuum pump specificly will draw at that elevation, and yes, you can AHIK.
                      • mack
                        • 2411
                        • Ontario, Canada
                        Ohh Lord
                        forgive me. I just wanted to ask a simple question. Brant, Greg, you guys need to get a secondary hobby. Normally I'd recommend fishing but on review I believe that would allow too much internalization. So I will instead recommend loud music and table dancers!!!!!
                        mack
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        613-398-6186
                          All good in theory, but those in. numbers ARE a tattle-tale of something a bit array if not within spec. realative to elevation location, same as if one or more have an erratic jump due to an occassional mis-fire.
                          • Rasputin
                            • 3189
                            • Lacombe, Alberta, Canada
                            I use the thing to equalize my draw on each carb no matter the number. That being said if the draw is too weak (eg 8 on the manometer) then I look at valve and cam timing issues. Too long since last used one but if the numbers are significantly lower than expected there are other things to check.
                            2-79 XS1100 SF
                            2-78 XS1100 E Best bike Ever
                              Sorry Mack, as a TOTAL gear head for 50+yrs., I hate fishing(loved elk hunting), and the poodle doesn't collect lint, so, your stuck with Greg and I's bantor back and forth.
