Do the forks lock? Suspension build?
  • adelii
    • Jun 2015
    • 94
    • Tuscon, AZ.
    I tried to lock forks like any other bike but key doesnt turn. Is there a trick? am i doing it wrong?
    What are you guys doing for suspension? looking to get the suspension a lot tighter. rebuild? im a big dude at 230 lbs. want to get some of the slop out of bike.
    79 SF
    • 9980
    The front wheel hast to be turned to the sop to get the lock to engage. I have to wiggle my forks a bit to get it to lock.
    There are 2 positions for the key when you do lock it. 1 click is lock only, 2 clicks is lock with park lights. Don't go 2 clicks and leave it parked to go to the lake for the weekend. Don't ask me how I know that.
      • 7795
      Start with the fork oil, change for new. I think you have air caps on the '79, but I'm not sure. If so, put about 12 to 15psi. A TKat fork brace is a MUST, tkat.com IIRC is the site. Rear shocks, there is a Honda air version that seems to work well. A search on "rear shocks" should bring up the threads.
      DO NOT forget the steering head bearings! Inspect and re-grease or replace as needed. I'm also 230, but I ride the 1980 Special so I know it's a bit different.
      • adelii
        • Jun 2015
        • 94
        • Tuscon, AZ.
        Where are you guys buying head bearing and fork seals? im going to buy all the parts first and make sure i have them before replacing everything.
        Can the rears be rebuilt or beefed up?
        hows your bike after working on suspension? since we are both 230 and all
        79 SF
          • 8054
          Custom springs will tighten it up. I got mine at Traxxion Dynamics. I'm over 230 lbs and mine is very nicely transformed. I added Race-Tech emulators as well.
