Petcock Fuel and Vacuum line route
  • b2b
    • Jun 2015
    • 10
    • Chandler AZ
    Hello first I want to say thanks for letting me join XS1100. Been reading from the out side for a while.
    Been trying to figure out how the fuel line and vacuum line route. I have a 79F. I am sure there was a T connection somewhere just not sure anymore.
    Thanks Paul
    79 F
    • 8930
    Hook the left petcock vacuum line to #2 cyl vacuum port, right petcock vac. line to #3 cyl vac port. Ports 1 and 4 to be capped off. Left petcock fuel line across and down to lower T on carbs 3+4, right one across to lower T on carbs 1 + 2. Inline filters can be placed in these lines if desired. The upper T's between the carbs are vents and those hoses are to run to ports on airbox. If airbox is not being used, leave those upper T's/hoses open to atmosphere.
    • russell
      • Aug 2002
      • 44
      • sydney australia
      Will it make a difference if I have run the fuel lines left petcock to lower T to carbs 1+2 and right petcock to lower T carbs 3+4.
      • MPittma100
        • Aug 2011
        • 2359
        Lines
        It is a little more difficult to add inline fuel filters that way and you have to be careful not to kink the lines with the sharper bends. You may not see kinks at first, but recheck once tank is lowered. The reason to cross the lines to opposite petcocks is to prevent that.
        Vacuum advance hose goes to the only available carburetor (not intake) nipple.
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
