Okay here is the problem.
I dont know if any of you have this issue in the past but here goes. As the temp here in Virginia rose Madness began to run worse and worse. Until finally unless I kept the throttle up it would just cut out. When it cut out I could smell gas big time.. I havent done anything else to the carbs after the airbox to cone filter thing. When I went out this morning had a hell of time getting it started so bad I had to charge the battery up. Now I can get it to start but OH BOy does it run rough.
Anyway the question is, what is the recommended timing setting and does anyone have any other ideas of what I should look at to for a solution to get me back rolling.
