charging question
  • graybird78
    • Apr 2003
    • 360
    • council bluffs iowa
    charging question
    how long should it take for charging system to reach 14 volts. seems to me it takes to long to reach 14 volts. holding throttle at 3k takes about 1 minute maybe more to reach 14 volts. its a slow and steady climb to get there. but it gets there. cant get above 14 volts . does that sound normal. maybe something else going on.had to fix wires behind fuse box. and rewire connector at the regulator. bike has always been reliable.
    when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
    graybird78
    80 sg (old faithfull)
    • 7831
    You may want to check the grounds at the reg/rec. Also, check the connector behind the fuse block if you have not already. How old is the battery? are the terminals clean? how is the battery ground to frame and engine? These are some of the common problems. I know you probably have taken care of them, but I'm just asking as I'm "working" at the moment.
    If all checks out, you may want to invest in one of Tony's reg/recs. They start charging a LOT sooner, and can handle more amps than the bike will put out, so they last forever.... The price can be hard to swallow, but an ebay one can cost $40 for the same old reg/rec that you have now.
    Link to site:http://www.oregonmotorcycleparts.com/Reg_rec_units.html
    • BowlingSS
      • Apr 2015
      • 398
      • Lawrenceville, GA.
      Those guys are high. Hope I never need one. I have a charging problem that I have not looked at yet. Still working on the engine, etc.
      Bill
      Jardine Spaghetti with Harley Mufflers
      • BowlingSS
        • Apr 2015
        • 398
        I noticed you are not checking the ampere's but just the voltage. Is there a reason for this. I would think measuring the ampere's would give you a better picture. What does everyone else think?
        Bill
          Bill, an ammeter would be nice.
          Graybird, how's the battery and the battery connections?
          If it helps you at all, the XS11 charging system is almost exactly the same as the old Chrysler/Dodge/Plymouth charging system but with a remote Rectifier bridge instead one bolted up inside the alternator. You can even use one of their old Regulators if the XS11's Rectifier bridge is still good but the Regulator goes to Silicon Heaven.
          Slow voltage rise and a low upper voltage limit could be one or a combination:
          Bad ground(s)
          Low/bad battery hogging the alternator output
          Bad Voltage Regulator connections
          Bad Voltage Rectifier diode bridge
          Full-Field the Alternator:
          The Brown wire supplies voltage/current to the alternator field coil.
          The Green wire is the return from the field and the Voltage Regulator, uh, regulates the voltage by controlling the ground.
          If you short the Green wire to ground at the 3-wire Voltage Regulator connector that will full-field the alternator.
          If the voltage comes up when you full-field the alternator there's a bad Regulator ground/connector or the Regulator is smoaked.
          • graybird78
            • Apr 2003
            • 360
            to all who have replied. the battery is 2 yrs old.has 70% capacity.battery connections are clean.battery shows 12.6 volts. 3000rpms with volt meter hooked to battery,voltage ramps up to 14.2 volts and holds steady.i have repaired the connection behind the fuse panel. ifound when i pulled the tank off to rebuild the petcocks and octy that the connector that has the three white wires and black and red wires that the red wire had gotten really hot ,melted the connector really bad. i had a spare reg rectifire but from an xj. wired it in seems to be working. i did not use the extra red and black wires. let me know if i should and were to connect them.never had any charging issues. any other connectors to look at. thank you for all your help.
            graybird78
            • BowlingSS
              • Apr 2015
              • 398
              How is your charging system doing now?
              Bill
              • graybird78
                • Apr 2003
                • 360
                well bill for the time being it is charging again.i did replace the regulator rectifier with 1 from an xj. im hoping it was just crapy connection .
                graybird78
                • BowlingSS
                  • Apr 2015
                  • 398
                  I am having the same problem. I have a donor 79 Special that has a rect/regulator that I might try. I think this one was replaced and looks new right before I got the bike.
                  Bill
                  • BowlingSS
                    • Apr 2015
                    • 398
                    Bill
                    I took the donor rect/reg and it looked pretty bad. I cleaned it up and installed it. The voltage looks a lot better now. I think I found my problem.
                    Thanks everyone. I am glad I have a donor.
                    Bill
