Looking for a little advice. If there are pre-existing posts please just send a link. Thanks.
(Does my picture show up? If not, how do you attach photos to posts?)
Changed my stock handlebars for a riser. I've been having brake issues this past year and I'm wondering if the angle of the MC is part of the problem? When the bike is upright, the stock MC sits at about a 30 degree angle now, slanted downwards towards centre of bike. The new bar setup also means the brake line is about 6 inches too long and creates an arc in the line as it comes from the MC to the Y joint. So my other question is when replacing the brake lines (SS of course), keep the Y setup or run two lines from MC to calipers?
Problems:
Last Fall: front calipers seized.
This past April: took the calipers off, had a mechanic check them out and rebuild. Using Dot-3 fluid as per the manual - reconnected the brake lines to the calipers, hand pumped the brake until fluid coming out of the bleeders was clean and bubble free.
Brake worked fine for a time, but got increasingly stiffer, until the lever was at a point where when pulled there was no feathering possible, it would just go full on. Loosened brake lever using the adjustment screw/lockwasher. Worked OK for a day or two, then the front caliper started grabbing again. Front right disc was extremely hot. I cracked the bleeder and the front wheel moved freely again. I checked the left disc, not very hot, and did not produce any fluid when bled.
What I plan to do next:
-Pull the calipers and check if they are seized.
-Drain the system.
-Remove old brake lines.
-Using MC kit, clean and rebuild - unless the angle is an issue.
-Get SS brake lines, not sure to keep Y joint or not
Problems:
-Drain the system.
