Ring Gap - 81 XS11
  • RichV
    • May 2013
    • 374
    • Everywhere
    Ring Gap - 81 XS11
    Well I checked my new rings in the cylinders for gap and all came in at less than .016". except for one set which came in a .022" (both 1st and 2nd). Should I be concerned? The repair book shows .008"-.016" with a max wear limit of .039". So the rings are well within the wear limit but outside the factory range.
    The gap does travel to other cylinders so it is the rings that are out of tolerance.
    I don't want to wait to replace a set of rings if these will do.
    _________________________________________
    1981 XS1100SH (Lola) - Bright Cardinal Red
    Whatever Lola wants, Lola gets.. Don't mess with Lola.
    Mostly stock with a few minor upgrades
    1981 XS11000SH being used for parts (Sold off)
    Also have:
    2009 Harley Davidson FLSTC with over 120K miles. All mine.
    Currently traveling the country with an aluminum can in tow and a motorcycle in the truck bed in search of the perfect road.
  • jwhughes3
    • 2798
    • Home of the Alamo
    If two rings on that cylinder measure a high gap I might swap one with the next cylinder to "spread the load" in case it becomes an issue.
    John
    '81 XS1100H - "Enterprise"
    • RichV
      • May 2013
      • 374
      • Everywhere
      John
      That's a good idea. It would reduce the risk of blow-by.
      Also have:
      • RichV
        • May 2013
        • 374
        • Everywhere
        Thanks for the help. I moved the rings around to place the wider gaps with the narrow ones.
        Also have:
