Rear master cylinder problems
  • unicorncomputer
    • Jun 2012
    • 140
    • Southern Vermont
    on my 79 1100 special my rear brakes were frozen. I was changing the tire anyway so I decided to remove and clean out the master cylinder. After putting it all back together, it doesn't seem to pump fluid at all. I did not take apart the plunger on the bottom. I am guessing that this is where my problem is. Does anybody have any pictorals on this and am I probably correct in that the plunger is where the problem is?
    Thanks in advance,
    Steve
    79 XS1100 SF
  • unicorncomputer
    • Jun 2012
    • 140
    • Southern Vermont
    Is there a way to test the master cylinder?
    79 XS1100 SF
    • MPittma100
      • Aug 2011
      • 2359
      Rear brakes
      You would be doing yourself a favor by rebuilding the master cylinder using a new kit. Also a good idea to rebuild the caliper especially if it has been a while. When you do, replace the caliper piston if pitted.
      Check your date on the brake line as it may be too old.
      It is best to bleed the brakes on these bikes with a vacuum gun bleeder. Pumping the lever is not often effective.
      1981 XS1100H Venturer
      K&N Air Filter
      ACCT
      Custom Paint by Deitz
      Geezer Rectifier/Regulator
      Stebel Nautilus Horn
      EBC Front Rotors
      Limie Accent Moves On In 2015
      Mike
      • unicorncomputer
        • Jun 2012
        • 140
        • Southern Vermont
        The system now has no fluid in it. Could it be fine and just not pumping fluid through with out a vacuum gun?
        I don't have such a tool, is there another way to accomplish it?
        Thank you for your knowledge.
        79 XS1100 SF
          • 7832
          You need to "bench bleed" the master before you put it back on the bike.
          With the master in a vise, and fluid in it, hold a finger over the hole the brake line bolts to. Push on the master with a screw driver or bolt or something to compress it, move your finger off the hole, then put it back on. Repeat until you have fluid coming out, the re-install on the bike, hook up the hose, and try bleeding again.
          • Rasputin
            • 3193
            • Lacombe, Alberta, Canada
            I do a different version of DiverRay's method, but on the bike. I simply remove the brake hose at the caliper end and use my fingers to seal it off there, while doing the push part with the brake pedal. It works for me.
            2-79 XS1100 SF
            2-78 XS1100 E Best bike Ever
            • SFerinTEXAS
              • Jun 2006
              • 877
              You are getting great advice on bleeding. The answer to your question is NO.
              Gonna have to take it apart and clean it, caliper too. The only way. May not need any parts.
              79SF
              XJ11
              78E
              • Fearthepack
                • May 2012
                • 255
                • Orlando, Fla.
                Don't forget the Spooge Hole in the master cylinder.
                1979 F worst one i could find
                to convert into a bobber/ streetfighter!
                _________________________________
                We can't all get along!
                • unicorncomputer
                  • Jun 2012
                  • 140
                  • Southern Vermont
                  Is there a pictorial anywhere on how to rebuild the rear master cylinder?
                  Just pulled the bike out and need to get this done.
                  Thank you in advance,
                  Steve
                  79 XS1100 SF
                    • 1590
                    Been looking for a tutorial. Here are a few things i found:
                    Some discussion about brake bleeding
                    Few pics of Front Master repairs
                    Few pics of Rear Master repairs
                    Not much help but maybe its a start. As stated, rear can be a bit tricky to get pressure.
                    As Ray said, with mine I did Bench Sync to get it primed, then needed Mighty Vac to get ALL the air pockets
                    out of the nooks & crannies in that rear brake system.
                    • unicorncomputer
                      • Jun 2012
                      • 140
                      • Southern Vermont
                      Thank you, I did find these too.
                      But since I have never rebuilt a master cylinder, I don't really know what I am in for.
                      79 XS1100 SF
                        • 1590
                        Its not complicated at all. Do you have an XS1100 manual?
                        If you look in CatatonicBug signature I think you can still download a manual there.
                        As Mike said, do the caliper too and check condition of piston for excessive rust + condition of that rear brake line if its original rubber it should be replaced just to be safe.
                        • unicorncomputer
                          • Jun 2012
                          • 140
                          • Southern Vermont
                          I got it apart. The bottom rubber piece came off before I could see what direction it goes in. I have pics here that I think are the right direction. Can someone confirm this?
                          And how the hell do you get the one in middle over the big piece at the bottom?
                          A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
                          79 XS1100 SF
                            • 1261
                            • Peachtree City, Georgia.
                            Bring the one in the middle down from the top not up from the bottom. It's new and quite pliable but I usually use a TINY bit of o-ring grease on it so it will slide over the humps easily (a LITTLE of any grease will do).
                            You have it assembled correctly in pic #2.
                            KURT
                            1982 - CBX1000 - Honda
                            • unicorncomputer
                              • Jun 2012
                              • 140
                              • Southern Vermont
                              Thank you all. It is back together and working again.
                              Now to clean the carbs and get the beast fired up and breathing again so I can get it sold.
                              79 XS1100 SF
