carb fuel tee
  • graybird78
    • Apr 2003
    • 360
    • council bluffs iowa
    carb fuel tee
    how does one change fuel tees between carbs.is it just o-ring that go bad. do you have to separate the carbs. mine just started to leak. also the the fuel petcocks wont shut off.oh the problems keep coming.guess nothing last forever.
    when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
    graybird78
    80 sg (old faithfull)
    Graybird,
    The fuel taps can be repaired, there are kits for everything. Do you still have the vacuum shutoff valve/Octy or is it gone? Here's a tutorial:-
    Special Petcock Repair
    Yes, you have to separate the carburetors to fix the tees. That will be an adventure but it's not too bad. The fuel tees are solid rubber molded over metal and they're available but they're expensive. You can repair the old ones with some o-rings:-
    Carb Tee Repair
      You can also buy new all brass tee'S from SCI. They are high quality but they are about $20 a pop.
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        Graybird,
        If you follow Scott's (3Phase) link to the Carb Tee Repair, Marty does post the link to SCI (Sirius Consolidated Inc.) at the end of the repair procedure.
        At the moment, they appear to be out of stock on the fuel tees (T4), but if you're interested in this option, you could try E-mailing them.
        And here is the link to the petcock repair kit from Georgefix:
        XS1100 SPECIAL PETCOCK REBUILD KIT
        It has everything you need to repair both petcocks and the Octy (if you still have the Octy).
        Marco
        1979 Honda CBX
        2002 Kawasaki ZRX1200R
        WE MISS YOU, DON
          YAMAHA CARB TEE FITTING
          "Out of Stock", but that's what I used.
          • graybird78
            • Apr 2003
            • 360
            yes i still have the octy.still works. will look into george fix parts. the fuel tees dont sound like fun at all.so the fuel tees have o-rings.i've own this bike for 15 yrs, never had any fuel leak problems,did have some float issues.
            graybird78
            • mack
              • 2411
              • Ontario, Canada
              fuel t repair
              mack
              79 XS 1100 SF Special
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              https://youtu.be/wB5Jfbp6SUc
              https://youtu.be/RaI3WYHSuWA
              Frankford, Ont, Canada
              613-398-6186
