DYI... Spooge Hole Probe
  • Fearthepack
    • May 2012
    • 255
    • Orlando, Fla.
    Had a real hard time clearing my clogged spooge holes.... everything I had on hand would bend or break.... so went to the closet pulled out an extra hanger cut it down to 4 inch size, put it in my drill... put drill in reverse and in high gear... turned on grinder it spins from top down so drill in reverse spins from bottom up this gave the most precise diameter to get the job done.... even taking as much off as it needed it still is remarkably strong....
    While your at it you mite as well make the necessary carb cleaning probes for all the various orifices....
    Um Honey what happened to all the extra hangers in the closet...... Um idunno..
    1979 F worst one i could find
    to convert into a bobber/ streetfighter!
    _________________________________
    We can't all get along!
    • 4015
    I'd be leery of sticking anything metal in anything on my bike that I cannot see, that needs to be cleaned. However, K&L and Mikuni does make a set of cleaning wires for carbs.
      Well, unfortunately you just enlarged the spoonge hole.
        Well, unfortunately you just enlarged the spoonge hole. Good luck.
          Worse yet, doing this probably left a 'burr' around the hole in the bore that will damage the seal....
            Hey, Feathers, nice job, man!
            Yes, you do have to make sure you don't leave a burr inside the master cylinder but then you have to do that even if you just poke a wire in there to get rid of the 'normal' brake system spooge and push it down inside the master cylinder too. Well, you're supposed to clean it out but the pressure return hole is just that: a hole.
            It is not a precision metering orifice, it's just relatively small to minimize that immediate fountain of brake fluid inside of the reservoir whenever the brake is released so it doesn't get all aerated and stop working.
            Keep it clean.
            • jwhughes3
              • 2798
              • Home of the Alamo
              That spooge hole is pretty far back in the bore. I think even if there were a burr its behind the point the rubber piston seal travels.
              I think he will be OK.
              John
              '81 XS1100H - "Enterprise"
                John,
                Not really. The best, clearest illustration I could find for a motorcycle brake master cylinder was over on the Harley TechTalk dot org site and it explains the pressure return.
                Scroll down the page to Reply #14:-
                harleytechtalk: Rear Brake Failure
                The images are linked from their site to i.imgur.com by the author:
                FSG
                BrisVegas in Oz
                • 1887
                  • 91
                  • Ottawa, Ontario, Canada
                  I checked it out, very informative.
                  Does anybody know the diameter of the spooge hole? My guess is .012"
                  1980 G
                  Jardine Spaghetti
                  http://s1337.photobucket.com/user/Ug...ish/slideshow/
                    Same size as your coat hanger....now.
                      • Fearthepack
                        • May 2012
                        • 255
                        • Orlando, Fla.
                        Let's see...I have a completely disassembled MC with clogged (white death) dry as the desert sponge hole....nothing could free it...the DYI did as soft as the hanger is I feel no damage inficked and would do it again if same conditions present themselves...the bore was honed after and before reassembly...results brakes that fully function.
                          • 8962
                          I see no problem using that tool, you and I would of course use it carefully not to inflict any damage. Others may not be so careful and possibly butcher things. Good job, glad you got the problem licked.
                          • Fearthepack
                            • May 2012
                            • 255
                            • Orlando, Fla.
                            My thoughts exactly.....others don't be afraid to use one if necessary...use it like your trying not to pop a ballon...all will be just fine...
