blinker switch? new member...
  • tomcos67
    • Apr 2015
    • 311
    • Amsterdam, N.Y.
    Blinker switch gone.Stuck on right turn.Won't disengage.no left .All very rough movement.Just never lube it yet this year.But it was working fine.Didn't take apart yet.Could someone advise me of next step.Couldn't find threads on subject.Don't know how to search.Is this something I can order.Thank You. Any help to get me pointed right direction..Thanks.Have a nice evening...New member..
    1980xs1100.sg Pacifica Fairing ..stock.
    2006 Honda Shadow Spirit 1100.! ⛺
    Pretty simple,,,,,undo the two screws holding the two halfs on the bars, remove, blast some electrical cleaner on everthing, a little dob of dielectic grease on switch moving pieces, back together..........but hey, don't be surprised when you find it looks like a forgotten 'science project' in there. Just gonna' have clean things up, along with ALOT of other forgotten preventative maint. would be my guess.
      These can be completely disassembled and cleaned, but pay very close attention to where all the parts go. They're also known for wires breaking off the terminals, but with a bit of care can be reattached.
      • tomcos67
        • Apr 2015
        • 311
        • Amsterdam, N.Y.
        turn signal, Switch
        Ok I didnt think It was fixable.But when I opened it up, there is a screw in there, worked its way out.Small screw on top of plastic thing.(shut off.) Anyways fixed now.Thank you!! GUYS.I've read alot of your posts, and still reading...Have a Great Memorial weekend...And Thanks to all you Veteran's.Peace.....
          ....might add, capture the little spring, or the man-cave will eat it.
          • MarkD
            • Jun 2013
            • 488
            • N. Michigan
            +1 on C.Steve's post. I took a pic of the switch after I ''halved'' it, then tore it apart ( carefully). I then thoroughly cleaned with WD40, and found a wire had come un-soldered from the board, which explained why one side didn't 'blink'. I re-soldered the wire, put everything back together, and wonder of wonders---it works like downtown.
            79 F
            1967 Suzuki X6 Hustler
            1973 Suzuki TM 125
            1979 XS1100 F
            2005 Kaw. Vulcan VN800
            1991 BMW K75
