Sorry,...another LED question
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    I installed LED rear lighting (blinkers & brake) and kept incandescent fronts,...worked fine. I just installed LED blinkers in the front and now they just stay on.
    I have a no load flasher in it now which is what I thought I needed. Is there a difference between "no load flasher" and "electronic flasher". When I Google search I see different terminology.
    I've also seen people fixing by installing diodes or resistors,...that's all Chinese to me. Hoping there is a plug and play fix.
    If someone can be so kind and post a link to what I need I would repay you in smiles...
    Rob - 79 SF
  • rover
    • Jan 2004
    • 765
    • central WI (715)
    Fix
    There is a fix, get an electronic flasher, plug n play.
    79 F (Blueballs)
    79 SF (Redbutt)
    81 LH (organ donor)
    76 CB 750 (gone to MC heaven)
    rover has spoken
      No Load is what you want. Some electronic flasher still require some load (I learned this the hard way).
      I did have to put a diode on each side of the turn signal circuit (right side and left side) to solve the problem when I went all led. If you use a resistor it defeated the purpose of switching to led.
      • mrhammer2u
        • Aug 2014
        • 472
        • Northern, NJ
        Hey Rover. To be clear, are no load and electronic flashers different? When I lookup electronic they look the same except for electronic seem to have ground wires.
        There are also 2 and 3 prong,...???
        Thanks!
        Rob - 79 SF
          Check this thread, it should help. The link to amazon shows a few flashers that will work.http://www.xs11.com/forum/showthread...D+turn+signals
            Hey Hammer,
            Like Nate said, you've got the 79SF, but it only uses 1 dash indicator light, and the power will leak thru that light to the other side, surprised you didn't say that all 4 were lighting up at the same time?! The diode(s) will keep the power isolated to the same side that is powered.
            Yep, you want the 2 prong style. I got an electronic one with a ground wire on Amazon, and it works just fine on mine, but I have an 81SH. I had an electromechanical one but I also have Incandescent dash indicator lights which provided enough load to actuate the flasher with my 4 LED turn signals. But then I put the new dual speedo/tach/electronic gauge cluster with LED indicators, and my flasher stopped working. The New electronic no load unit worked fine, but of course I don't have or use the self cancelling feature.
            • mrhammer2u
              • Aug 2014
              • 472
              • Northern, NJ
              Hey all,...here's an update on my LED issue.
              I think I found the fix. People kept selling me electro"mechanical" flashers. I went through 2 or 3 of them before I did enough research to figure out the peeps at Pep Boys and Advanced Auto Parts didn't know the difference.
              So I have an electronic flasher on the way. The only one I can find within a 20 mile radius was a square one which I don't feel like fighting to get in the rubber loop. Hoping this is the plug n play cure I'm looking for.
              Rob - 79 SF
