Gas leaking from U joint boot
  • Gas leaking from U joint boot
    So, how screwed am I?
    Over the winter, the crankcase filled with gas.
    I drained it, changed the filter, put new oil in.
    Today, I rode my bike to work for the first time this season. About a half hour trip.
    Now, there's a sizeable amount of gas and rotten smelling oily liquid on the ground. It's coming from the nipple on the bottom of the u-joint boot.
    I've got a trip next week on the 14th to Kentucky. It's my only bike trip of the year. Really hoping I'm not going to miss it.
    Mike C
    Lake Orion, Michigan
    '78 XS1100E
    Here I am! Where are you?
    Probably what leaked from the tank over the winter went into the swing-arm as well as the crank. I would drain the middle drive and refill it, and pull the rear wheel off, then take the 4 bolts off and pull the final drive as a unit. You should then be able to clean everything out, re-grease the splines on the final drive with moly EP grease, and re-assemble. That SHOULD take care of things, but a good inspection IS in order.
      Thanks Ray.
      I'll get on relubing the whole kit and kaboodle.
      Just printed out c-bugs dipsticks.
      I'm at work, so tools on hand and resources are limited.
      Mike C
      '78 XS1100E
        Yeah, I'm at work as well. Tuning radio's.......
          Originally posted by Fix View Post
          Thanks Ray.
          Let me know if you need any help Mike.
            Thanks, Ian.
            Here's hoping I can get over to your side of the state this year for a ride. I have some friends over there at checkered past motorcycles in Galesberg.
            Mike C
            '78 XS1100E
              I think Ian's side of the state is about 20 miles north of you.
                Lmfaooo. Mike, I thought the same thing.
                  I need to get my eyes checked. I swear I saw Grand Rapids!
                  Mike C
                  '78 XS1100E
                    We're all friends here.
