Front tire cupping
    Hey again Bart,
    That description sounds like too tight steering head bearings which are not allowing the front wheel to AUTO-track via the caster affect...it's HOLDING a position/binding. The steering head bearings need to be a little loose to allow the wheel to swivel easily, hence like Motoman said, need to be loose enough to let the bars flop with just the slightest push/touch/nudge from center.
      Hi Bartman,
      While the others have you checking the steering head bearings.
      I have a stretch of ROAD near me that does that to mine
      Certainly check the bearings but ride some different surfaces too.
      • Bartman
        • May 2012
        • 200
        • Jefferson, Georgia
        Update on the oscillation, I slowed down for 4K miles and wore out the back tire.
        Replaced the back tire and hand balanced this time instead of paying someone else. All seems good now.
        History: I now have put 16000 miles on the bike.
        16000 miles ago I replaced both tires first time and used dyna beads= good balance and no oscillating.
        5k later I replaced rear tire and used dyna beads, no problems.
        5k later paid motorcycle shop to mount and balance tires. Resulted in many weights and oscillating in deep curves at 70 mph. My son came home from college and road it and came right back saying it had a problem, (forgot to worn him).
        I bought a wheel balancer and just replaced the back tire myself with weights and now all is good again.
        SO the problem was a bad tire OR the shop didn't balance it well.
        Now that I am working on the keeper bike I found the if you ram the cones in too deep that they can catch on the pipe inside of the wheel and not allow a good balance.
        79 XS11
          .........interesting.......went all the way from front tire cupping issue to quarter mile times........and back. Y'all need to spend time riding more........often.
            • 5057
            #35
            What ...does...that...mean???
