Scored a carb syn tool
  • Jeffintampa
    • Apr 2011
    • 344
    • Zephyrhills, Florida
    hmm
    wonder how I would set them if they are off? I did plug each one into 4 slot and it did seem like a different reading each tube. How in the heck would this be adjustable. I turned the nuts on top almost a full turn tighter did not move were the ball was bouncing.
    Bike History:1980 XS 1100 special current bike
    1980 XS 850 special wife sold
      • 7828
      You NEED to do at least two at one time, thus the need for a "T" or "Y" fitting. You then check that they are both the same, from the same source, at the same time.
      • CaptonZap
        • Jun 2010
        • 1748
        • Denver
        It sounds like you need an orifice in the lines to reduce the bounce.
        • Jeffintampa
          • Apr 2011
          • 344
          Well
          Well what I did was put tube 1 on 3 carb, but 2 on carb 3 they seemed almost spot on the same reading. So I put tube 1 on 3 then set #4 on tube 2 to match, then went to 1 and 2 setting all with tube 2 keeping 3 on tube 1. Bike seems to run pretty good.
