bike hit while parked
  • kevxs
    • Apr 2009
    • 353
    • toronto
    Walking to my bike after work today I see a car pulling out and it hits my front tire and knocks my bike ino the vespa beside it. The impact sheered the bolts that hold the ignition/steering lock unit. Wondering what the procedure is remove the upper triple tree so that I can remove (easy out) the broken bolts so I can reinstall the unit. I am hoping the steering lock mechanism is not broken but I can't confim that yet. I have the factory manual but cant find that specific procedure. The vespa that broke the fall took a worse beating.
    Thanks
    1979 XS1100SF 37000km
    Green Dyna Coils
    Stainless Brake Lines
    1973 CB100
    kevXS
    • 6762
    what and you didnt get the the stupid cager ???? I would have gotten the license plate #...
    persona non grata
    • kevxs
      • Apr 2009
      • 353
      • toronto
      I got all her info. She didnt hit and run.
      Green Dyna Coils
      1973 CB100
      kevXS
        • 6762
        ah thats better...at least she was a responsible idiot cager...
        persona non grata
        • kevxs
          • Apr 2009
          • 353
          • toronto
          If I get a new ignition switch can it be made to work with my key or do I have to now buy new ignition switch, gas cap, side cover and helmet lock to have it all work with 1 key?
          Green Dyna Coils
          1973 CB100
          kevXS
            • 7863
            The locks have to be changed. I think the new lock can have the tumblers (or whatever their called) moved to match the old lock.
            • donebysunday
              • Oct 2012
              • 1737
              • New Berlin, Wi.
              Should be able to swap the cylinder with tumblers from the old to the new. Leaving the key in is the only way to remove and you still need to push that locking tumbler at the bottom in to release it. If you take the key out at any point before installed parts will fly.
              76 XS650 C ROADSTER
              80 XS650 G Special II
              https://ibb.co/album/icbGgF
              80 XS 1100 SG
              81 XS 1100LH/SH DARKHORSE
              https://tinyurl.com/k6nzvtw
              AKA; Don'e, UD, Unca Don'e
              • kevxs
                • Apr 2009
                • 353
                • toronto
                can anyone give some insight into replacing the triple tree? 1 shop I called said $400 cause the whole front end has to come apart, the other shop said $100 and the whole front end doesn't have to come apart. I just want to get a good idea what I'm dealing with so I can tell the lady how much she owes me.
                Green Dyna Coils
                1973 CB100
                kevXS
                • tcoop
                  • Nov 2009
                  • 793
                  • South Weber, UT
                  If your only replacing the top part of the triple tree
                  4 bolts to remove the handle bars
                  Remove the steering head bolt
                  loosen 3 bolts that clamp the tree to the forks and steering head
                  2 bolts to remove the gauges
                  2 bolts to remove the ignition switch.
                  Pull out top tree and remove broken bolts. (or replace top tree)
                  Remove the head light ring and pull out the headlight
                  Swap in new ignition switch.
                  Put all back together
                  If your fast all can be done in 45 min... if your like me (easily distracted) about 2 hours
                  Top tree - $30~
                  Labor 2 hours @ Mechanics rate
                  Ty
                  78 XS1100E - Now in Minnesota
                  80 XS1100LG - The Punisher
                  82 XJ1100 - Daughter's Bike
                  • kevxs
                    • Apr 2009
                    • 353
                    • toronto
                    perfect, thanks so much
                    Green Dyna Coils
                    1973 CB100
                    kevXS
                      • 7738
                      If it just sheared the mount bolts for the ignition, you should be able to get them out somewhat easily. When you put the front end back together, there is an order to tighten the bolts. YOU NEED to follow that order, or the bike will NOT handle well!
                      • kevxs
                        • Apr 2009
                        • 353
                        • toronto
                        ok thanks I'll make sure I read up on the procedure in the manual.
                        Green Dyna Coils
                        1973 CB100
                        kevXS
                        • kevxs
                          • Apr 2009
                          • 353
                          • toronto
                          just got a $200 e-transfer to cover the damage, seems fair to me.
                          Green Dyna Coils
                          1973 CB100
                          kevXS
                            Hi Kev,'''
                            As long as you are satisfied that's all that matters. Do check the triple tree for any other damage/ cracking.
