Intake Manifold (Boots) Install Gasket Recommendation
    • 3954
    Just ordered some. I know they come with the paper gaskets. Abybody recommend anything different? RTV? Permatex The Right Stuff?
    Light smear of whatever your preference of silicone gasket maker.
      • 7819
      I use just a VERY LIGHT smear of Yamabond #4 on mine. The non hardening Permatex is close, and will work as well. I stay away from the silicon anymore because of what I've found on tear downs. It tends to leave bits floating around in the engine after a while. NOT what I like to find.
      • LoHo
        • Sep 2002
        • 1342
        • Fresno, CA
        Those thin paper gaskets can gradually disintegrate and give you a hard to find vacuum leak. I took my boots off, scraped off the paper, and used copper RTV because I had it on hand. So far, so good.
          • 9981
          Throw away the gaskets and do as DiverRay said.
          • TexinMaine
            • 160
            • Norway, maine
            I just did the same thing Ian, but the gaskets coming with mine look like a blue fiberglass material. Is this Yamabond #4 stuff common? There is a local Yamaha dealer I may check tomorrow and see if they have it.
            1981 XS1100H
            Quando omni flunkus moritati
            When all else fails, play dead.
              • 9981
              Posted what you need on the other site Tex...
              • Rasputin
                • 3193
                • Lacombe, Alberta, Canada
                Atta boy Greg!
                2-79 XS1100 SF
                2-78 XS1100 E Best bike Ever
                  • 9981
                  Originally posted by Rasputin
                  Atta boy Greg!
                  That's where I read it first....Doug.
                    • 9981
                    Everybody should have at least one tube of this, I keep 2. One at work and one at home. It works well on automotive applications also so it's part of my toolbox at work.
                      • 3954
                      Greg swears by the 1194, as he should- it's proven itself for him, even in auto applications. However, for myself I find myself buying Permatex's "The Right Stuff", for every gasket application. I smeared those on the boots and installed them.
                      I did however buy a new valve cover gasket, and sprayed it down with PAM.
                      • Jeffintampa
                        • Apr 2011
                        • 344
                        • Zephyrhills, Florida
                        Intake man gasket?
                        The rubber intake manifolds between the carbs and engine have a gasket? Didn't seem like it when I changed them the old ones were leaking and loose on #3
                        Bike History:1980 XS 1100 special current bike
                        1980 XS 850 special wife sold
                          • 3954
                          Yup, they sure do.
                            • 7819
                            Yup, they sure do.
                            Actually, only the aftermarket ones do. Stock had an "O" ring molded into the rubber, and didn't use a gasket.
                            • Bergman16
                              • Jun 2014
                              • 286
                              • New York, N.Y.
                              Just curious, are the NOS boots significantly better (or worse) than the aftermarket? They seem to fetch a pretty penny on Ebay, and wonder if it's worth it for 30+ year old rubber...
                              Steve R
                              '80 SG
                              "Fred" -- TC fuse box, stock airbox/exhaust/jets, SS brake lines, Windjammer V fairing, Cibie headlight lens, TKAT fork brace, Showa rear shocks, MikesXS emulators
                              Former bikes:
                              1973 Yamaha 125 Enduro (brother's but I 'borrowed' it a lot, usually after midnight)
                              1978 XS400E Red
                              1981 XS850 Special (Stingo)
