brake master debacle
    • 7941
    Yes, my writing skill leaves something to be desired. Suffice to say the 16mm master piston works better for this application.
      • 3918
      Definitely do not want to confuse the thread, but Phil advised me on a 14MM front MC, and it's a world of difference from the stock MC. That stiff brake mentioned is much more soft with the 14 mm.
        • 8797
        Yep, 14MM is fine on a Standard with the smaller caliper pistons. The Special's larger caliper pistons need at least a 16MM master.
        • ViperRon
          • Feb 2011
          • 1062
          • Woodstock, VA
          Volume becomes an issue if you use the original lines or longer lines that are not Stainless Steel because more volume is needed across a larger span like longer tubes and you can have swelling. I think that if you are going with a smaller master you definitely should use the stainless steel lines. I personally have the original setup but all rubber and seals have been replaced. No matter the load with 2 people I can make both brakes start to skid on a ruff hard road and that is the best you can get. However you need real flexibility with the front brake so it does not grab all of a sudden. On a dry road going straight your front is most of your braking power. Slick road or in a turn you do not want that front to grab you want sensitivity so you can feel it. Same applies to the rear to a degree but its easier to recover or control the slide out. A quick hard front brake action can slam you on the pavement.
          The end result is it must slide wheels with load but be sensitive enough you can control it.
          Rodan
          1980 G Silverbird
          1198 Overbore kit
          Grizzly 660 ACCT
          Barnett Clutch Springs
          R1 Clutch Fiber Plates
          122.5 Main Jets
          ACCT Mod
          Mac 4-2 Flare Tips
          Antivibe Bar ends
          Rear trunk add-on
