1980 Exhaust Header Collar Shorter Than 1978-1979
    • 4015
    So, I just found the source of my exhaust leak. Better than bent valves! If you can visualize it, the collar that goes into the header on the #1 pipe is shorter than the rest of the pipes, so the flange is not compressing the collar into the cylinder to seal it. So, my options are . . . double-up the gaskets on that cylinder?
    That would be one easy way. The other thing you could try is make a 2 part ring to space the flange the same as the others.
    The Kerker headers I put on the '80 engine were designed for the '79 standard. I had to cut the collars about 1/4" as I had one exhaust stud that would NOT BUDGE. Since the engine was painted and in the frame, modifying the exhaust was the easiest way.
      • 4015
      Yes, that sounds pretty smart!
        Yep, that's the big difference between the 'early' and 'late' exhaust. You need any spacer between the collar and the flange, NOT between the collar and the head as that will shift the position of the pipe forward and put the other connecting parts into a bind. Or just put a 1/4" spacer under the flange nuts on that pipe. This will cause that flange to be closer to the head, but it's strictly a cosmetic thing....
          • 4015
          In theory, if I'm using studs much longer than the OEM 30mm, and using elongated nuts, is there a difference in clamping pressure on those flanges, versus stock nuts and stock studs?
            As long as the nuts don't bottom out, no difference....
              • 4015
              Thanks to Steve's exhaust thread, he noted that the difference between the '78-'79 collar, and the '80 collar is 1/4". I will now either fabricate a spacer, or look on McMaster's site for something.
                A 16 gauge, 1/4" wide strip of sheet metal would work. Pre-roll it if you can, or just slowly wrap it around the pipe, tapping with a small hammer to get it close. Should be all you need. If you start with 6", you can start with a strait part to hold in a vise next to the pipe, and work it from there.
                  • 4015
                  Great recommendations Ray! I ended-up using a piece of 1/4" aluminum, then used a 2 1/8" hole saw for the outer perimeter, and an 1 7/8" hole saw in the middle of it. Cut a perfect donut, which I then cut in-half. Fits perfect around the header pipe. Should provide enough clearance between the flange and collar.
                    The aluminum MAY "squish" a bit much. Keep an eye on it! never mind, just re-read and realized you used a solid chunk.....
