gas in airbox
  • DAVINCI
    • Jan 2011
    • 1048
    • Cedar Mountain, NC
    BTW...petcocks do not operate on vacuum
      • 4015
      The STANDARD petcocks do not operate on vacuum??? I know the Specials do not . . .
        You got it, Ian
        The Standard uses vacuum; Special uses the infamous Octy.
          The octy is vacuum controlled as well. Just for the record.
          The Special really got the best set-up. It has positive shut-off petcocks and a vacuum safety valve. IMHO, they should have all been done that way.
            • 6765
            Randy disabled the vacuum on this bike....thats what he is referring to
            2005 Honda SilverWing 600
            2018 Honda PC-Xpress 150
              Ah! Thank you, max; marty!
              <slinks off into the sunrise>
              • vedgar
                • 311
                • Clarkston, Michigan
                trick for leaking gas.
                remove the air box lower cover. Check carb intake bells for wet gas, determine which carb is leaking. Remove the drain bolt at the base of the float bowl for that carb. Using a small amount of compressed air blow In that float bowl hole. ( This will usually clear any debris and help stop the leak.
                79 1100 SF Carmine Red stock
                85 Honda v65 Magna
                  • 6765
                  I'll have to remember that the next time gas gets into the airbox...Thanks
