Tire Shimmy
    • 4015
    Tire Shimmy
    Had the tires mounted and balanced at a dirt bike shop a week ago. Having installed the front wheel and spinning it countless times to make sure the new rotors are not hitting anything, I noticed that the wheel does not spin true. The tire kinda slowly sways left to right looking at it head-on. Is this normal? If not, what could be causing it? Improper balance? Axle nuts not tightened properly? Bent axle? Bad bearings?
    It is probably the tire, what brand do you have, Shinko? Sometimes tires are not perfectly round, especially the cheaper ones. First check to make sure that line is visable all the way around the rim on both sides.
      Could be it's not seated right on the rim too.
        My experience with those out of round tires is you really have to ride on them first, sometimes they ride just fine, others ones you will feel a wobble of some sort. If the wobble is enough to bother me, I take the tire off and send it back to the vendor as a reject, they pay for shipping both ways and replace the tire. Sure I am out my labor time, but that's just life. If a dealer sold you the tire they should replace/mount it for you free of charge. I've had this happen with 3 out of my last 10 Shinkos. Hope yours rides just fine, Ian. Good luck!
          • 4015
          It's a Metzeler Lasertec. It was a young guy who mounted the tire, and said he had great difficulty mounting the back tubed tire due to the rim locks on both sides. He also said he was having difficulty balancing the front tire. I hope he knew what he was doing.
          Tires have not been rode-on yet. I hope the wobble is not from any nuts not being tightened-down enough. Axle bolt was tightened to 66 ft. lbs. (77 ft. lbs. is spec), and axle pinch bolts were hand-tightened to a point where I felt comfortable (broke the stud prior).
          • TADracer
            • 1417
            • Kenner, Louisiana USA
            probably the mounting. I have used Lasertecs for years with no problems whatsoever. In fact, just mounted a new set about three weeks ago. You need to watch how it mounts when airing them up to seat them. Check by teach side of the rim while it is spinning. If you are off then it will show there.
            Mike Giroir
            79 XS-1100 Special
            • ViperRon
              • Feb 2011
              • 1062
              • Woodstock, VA
              Just to be sure take a block or something and put a screw driver or wrench handle on it and put it next to the rim and spin it. If the rim rides pretty close to the same point while going around its got to be the tire either mounted wrong or bad. If that rim moves much check the bearings. If its not the bearings check the rim for tire machine marks. More than likely the tire is not seated proper.
              Rodan
              1980 G Silverbird
              1198 Overbore kit
              Grizzly 660 ACCT
              Barnett Clutch Springs
              R1 Clutch Fiber Plates
              122.5 Main Jets
              ACCT Mod
              Mac 4-2 Flare Tips
              Antivibe Bar ends
              Rear trunk add-on
