where can I get a set of rear wheel bearings for my 79 special? can I cross reference them at a bearing supply shop?
rear wheel bearing sources?
Re: rear wheel bearing sources?
The old gray biker ain't what he used to be. -
Geezer,
Have I missed a post or is there a supplier other than Yamaha that has the left rear bearing? I even went direct to Koyo on that one and they don't even admit that they made it!
I bit the bullet and paid the piper his $40.
If you've got another source, please share it with us.
RandyComment
Originally posted by randy
Geezer,
Randy
The old gray biker ain't what he used to be.Comment
The manufacturer of the bearing is NTN, a Japanese company. From what I've heard, good luck finding it. There are a lot of bearings that are limited availability like that. A cylindrical roller bearing is going to be more expensive than a ball bearing anyway due to the manufacturing process. If your local dealer's margin is 40%, you would save $16 if you found it elsewhere. I used to work for Koyo Corp. so I called my friends at Koyo, with no success. For $16, I chose not to spend any more time on it. Unlike the other bearings, you'll never be able to get that one sealed or shielded due to the size and application.2010 Kawasaki Z1000
1979 SF: Millennium Falcon, until this SaturdayComment
