new carb intake boots grrrrrr
  • Jeffintampa
    • Apr 2011
    • 344
    • Zephyrhills, Florida
    Well all this is why I need help and suck at working on my bike.
    I went step by step and took my carbs off and put new intake boots on today.
    all in all it wasn't to bad hardest part ways getting the carbs to seat in the boots but got it done. I drained my tank while it was off, cleaned out my filters on the shut offs.
    Put it all back together and went to put gas in the tank,............. gas was running out of my air box wtf?
    HHHHEEEELLLLP
    Bike History:1980 XS 1100 special current bike
    1980 XS 850 special wife sold
  • brcree
    • Mar 2010
    • 388
    • S.C.
    Stuck float..............also...I use liquid silicone on the boots insides.
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
      Hey Jeff,
      Yep, when you drain the carbs, the floats can drop so far that the float needle can get cocked/stuck and prevent it from moving/sliding back up into the valve seat as the bowl fills with fuel and the float experiences buoyancy pressure. A few taps with a dead blow plastic hammer or such on the sides of the carb assembly can often help to loosen/wiggle the floats/needles and allow them to move freely and then perform their proper function of stopping the fuel flow when the floats rise to the proper level.
      • Jeffintampa
        • Apr 2011
        • 344
        Better
        Seems to run better, when I took off the old carb boots the #3 one had a lot of what looked like carbon blow out around it and the nuts took no effort to take off.
        Well changed the oil and filter did the cam change adjustment, and newer intake boots and it does sound different.
        40-50 miles and I let you know for sure...
        Thank you all for all your help.
        • mack
          • 2411
          • Ontario, Canada
          drop tangs
          The floats can stick if the drop tangs aren't engaged properly. If this was the case then the tapping with the end of a screw driver may not do the trick.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
          • CRXSi90
            • Jun 2004
            • 400
            • Madison, Wisconsin
            That's my next order of business...getting the carbs reinstalled ...thanks for the tip.
            '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
            '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
              Not a bright idea. That will end up going through the engine and possibly causing fatal damage.
              Bite the bullet and get some new boots. $65 is cheaper than a new engine.
                Greg, He HAS new boots! The liquid silicone is a spray like oil. I use it here for the same thing. Works well, though on 35 year old rubber, heating it up and then the silicone works better.
                  OOPS......Sorry. Misunderstood.
                  • brcree
                    • Mar 2010
                    • 388
                    • S.C.
                    boots
                    Sorry guys ...I should have said...use liquid silicone on "new" boots.....old will work but...why go through the trouble, get new ones.
                    At this time:
                    1985 Goldwing Innr.
                    2007 vtx 1300
                    81 sx 1100 s h
                    81 sx 400 special
