Best Way to Support Bike With Wheels Removed
    • 4015
    Okay, visualize that the bike is in a storage garage with no lifts, etc. I do have a floor jack and jack stands. The bike is apart, and not going anywhere. What is the best way to support the bike with tires removed? I'm scared to have any pressure on the oil pan. Is that a legitimate concern? I'm thinking of cutting a bunch of 2x4's and running them parallel to the cylinders . . .
    I've got one sitting on one of these.. easy to roll around.
    http://www.harborfreight.com/movers-dolly-93888.html
      • 4015
      Lol, I used the lighter one of those for my engine when it came-out, and it split right down the middle. Don't ever try to load ur XS engine on those cheap carts with the handle either!
      Wouldn't the forks be hitting the ground with that under the oil pan?
        Yeah, didn't think about that. The whole front end is off that bike, but i've had good luck with those dollies.
          If the engine is in the frame, do NOT worry about the oil pan. If it's going to just sit in one place while you put parts back on, Jack it up and use a 2X4's to support it. Lift from the balance point with the jack out one side, and put the 4X4, or 2X4 stack on either side of the jack. I almost always put a short 2X4 between the jack and the engine, to keep from marring the bottom.
          Your other option is a com-along from a rafter. Loop it around the front and rear of the frame, and lift. That is how I picked up the frame/engine of the '79 to put the forks, swingarm, and wheels back on it.
            All I ever do is use the factory centerstand, and put a jackstand under the front lower frame cross tube.
              • 4015
              This will allow both tires to be removed at the same time?
              • tcoop
                • Nov 2009
                • 793
                • South Weber, UT
                Yep.
                Ty
                78 XS1100E - Now in Minnesota
                80 XS1100LG - The Punisher
                82 XJ1100 - Daughter's Bike
                • jimbyjimb
                  • Feb 2010
                  • 263
                  • Seattle
                  Been doing the exact same thing for years. I use a screw-type bottle Jack. Bike is rock solid like this.
                  1990 Ninja ZX-10. It's the Silver Surfer. HI-YA!!
                  2006 Yamaha XT-225. Yep, I take it on the interstate. It's Blue Butt.
                  1982 Toyota 4x4. 22R Cammed, 38/38, 2" pipe, 20R head with OS valves, performance grind and other fun stuff. It's Blue RASPberry.
                  1969 Ford F-250 Camper Special resto project. 390 RV cam, Demon carb, Sanderson headers, 2 and a quarter pipes with Magnaflow mufflers. It's Blue Jay.
                    Originally posted by tcoop
                    Yep.
                    .....pretty much how we all get'r'done.
                      • 4015
                      Wheels successfully removed using a floor jack under the crossmember, on the center-stand. Wheels soon to wear new rubber and rotors. Thanks fellas!
