stator check
  • mack
    • 2411
    • Ontario, Canada
    stator check
    Was reasembling my generator today but before I did that I decided to check the field coil and stator. The manual calls for .4 oms between the whites. I was getting .8 at white to white. If I go, any white to yellow I got the .4 called for. Seems like a poorly worded illustration. So I checked my running bikes and they were the same. Is this correct or is my voltmeter crap?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    • 4013
    Hopefully by "voltmeter", u mean "DMM", or "Multimeter", correct? I know you know, but I'd hate to see someone see this and think to use a voltmeter to measure resistance. But, I always just measure white to white, then the field coil wires. Not sure I ever used the yellow wire.
    • mack
      • 2411
      • Ontario, Canada
      Yes
      your right, I meant multimeter.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        Does your meter 'zero out' when the leads are touched together? If it doesn't, subtract whatever it shows from your reading across the coils. And keep in mind that even a quality hand-held meter will only resolve down to about .1 ohm, not all do that well.
        A slightly high resistance will reduce output some but not enough to matter on a stock bike.
