Why...... on dremel fix?
I think what might be causing the confusion is the wear is only evident on the tips of the dogs. The reason of this is that is the part of the dog that first makes contact with the other gear when you shift. At that instant, the parts are generally spinning at different speeds, so that tip has to absorb the full force of bringing the engine and bike into sync. That shock of that impact causes the tip of the dog to be worn.-- Clint
The gears are hardened for wear; they're cast iron and if they weren't they wouldn't last long. But the shift dogs aren't exposed to the same wear, the only time there's wear present is during shifting. Shift with the right technique and there will be little or no wear, be sloppy about shifting and you'll be right back in there fixing it again....Fast, Cheap, Reliable... Pick any two
Originally posted by crazy steve View PostShift with the right technique and there will be little or no wear, be sloppy about shifting and you'll be right back in there fixing it again....Dell82
Houston, TX
82' XJ1100J Maxim "LASERMAX"
SOLD 86' Kawasaki Voyager XII, 1200cc SOLD
SOLD 82' CB450SC Nighthawk, FOR SALE SOLD
SOLD 82' CB450SC Nighthawk, parts bike SOLD
Originally posted by DELL82 View PostSo with my shin at an acute angle to the bottom of my foot makes it difficult to shift. That said if I could sit further back on the XJ1100 then lifting the foot would be easier. I may be weak or the angle of my shin is way less than 90 degrees. A heal toe shifter can remedy this problem I'm sure. Then what is the proper shifting technique?.
I enjoy watching Youtube videos and listening to guys shift, and wonder who taught them, lol. I hear a lot of short shifting, usually from 2nd on up, and wonder if they think they're in a semi-truck. When I hung-out with my yoinger brother and Gabe (Down$hift), I was surprised to hear them shifting with no purpose, other than to make their foot useful.1979 XS1100F
Shifting is sort of like balancing the bike you have to get to the point where all actions and movements are muscle memory you do not really think about it much you just automatically respond. Turns and how to lean on what type surface starts to come natural as well as braking how much pressure on front and rear. The only way you get it is by riding more. So all you need is to ride more.To fix the problem one should not make more assumptions than the minimum needed.
Rodan
1980 G Silverbird
1198 Overbore kit
Grizzly 660 ACCT
Barnett Clutch Springs
R1 Clutch Fiber Plates
122.5 Main Jets
ACCT Mod
Mac 4-2 Flare Tips
Antivibe Bar ends
Rear trunk add-on
Originally posted by DELL82 View PostThen what is the proper shifting technique?
It's the popping out of gear under load that really kills the shift dogs, or god forbid, shifting without the clutch. Yes, some bike transmissions will tolerate this type of technique/treatment, but not this one. Yes, it will shift somewhat 'clunkily' this way (although practice can reduce this somewhat), but that's the nature of the beast. Some of this was noted in the original reviews by the way....Fast, Cheap, Reliable... Pick any two
Lesson learned
on this list that when you dremel an angle to the dogs and slots to match they will pull themselves together, this depends on how far down the dog you dremel in the angle.
Did I say that right ?
I'm thinking with the angle on the dogs and slots the washer might not need to be swapped. Whatcha think ?
Thanks for all the help y'all gave me when fixing that one I did just to see how it was done, then sold it. I still contact the new owner to see how it's held up and he likes it so much he now has a standard F as well.76 XS650 C ROADSTER
80 XS650 G Special II
https://ibb.co/album/icbGgF
80 XS 1100 SG
81 XS 1100LH/SH DARKHORSE
https://tinyurl.com/k6nzvtw
AKA; Don'e, UD, Unca Don'e
