Identifying a Bad Caliper Seal
    • 4015
    Re-building my R6 Calipers. What signs besides gouges, etc., could I use to identify a bad seal? I really see nothing that sticks out.
    Worn seals won't be obvious.... Look at the seal face that contacts the piston for signs of heavy wear (microscopic lines or wear marks) compared to the other sides. If the entire face shows none of the original finish, the seal is probably worn too much. Another check is when you reassemble the calipers, if the piston pushes into it's bore too easily, the seal is worn too much. You should have to give a pretty good 'push' on the piston to get it 'started' into the seal; once it's in, it should push in the rest of the way with only moderate pressure. Make sure you lube the piston/bore with some brake fluid or red rubber grease.
    My experience is that any seal with under about 50K miles will be reusable unless there was 'issues' in the caliper and/or rotor such as corrosion, a damaged piston, or a out-of-round rotor.
      • 4015
      The seals looked okay, but my gut told me to buy a rebuild kit for the calipers anyways. It's good insurance, as the pistons cleaned-up well, and I don't need a tiny piece of rubber being my downfall.
      • clcorbin
        • Jan 2010
        • 495
        • Albuquerque, NM
        You have to hate that! On the bright side, when you tear it back down to replace that seal you decided not to replace originally, it is MUCH easier to get apart and MUCH cleaner too!
        -- Clint
