Plastic Side Cover Repair
    • 4015
    Tried pulling the side cover off in the cold, and a chuck of it broke-off clean. Any and all advice on repair is appreciated.
  • BigOates
    • Mar 2013
    • 71
    • Montgomery, Al.
    I've used some two part epoxy and gorilla glue to fix mine before, both with good results.
    Jason
    Montgomery, AL
    80 XS1100SG Daily Driver
    81 XS1100SH (Getting ready for an engine rebuild)
    86 Honda Magna V45 (sold)
      Ian read up on ABS welding. A clean brake should be an ideal candidate.
      While I have never done it myself it does not sound too difficult to do.
        • 4015
        Whoa! I see bad things happening with using heat to fix this break. I'll look into some plastic glue and cross my fingers.
          Go to a body shop! If you don't have them fix it, you can at least find out what they're using for the repair. I have had two side covers fixed. If either of them breaks again, it won't be in the same place. There are specialty adhesives to solve this problem permanently.
          • Eastcoaster
            • Jan 2012
            • 513
            • oceancity NJ
            J-B weld is one of my best friends. I backed it up with some fiberglass repair on the inside
            82 XJ1100J
            81 Venturer
            • jwhughes3
              • 2798
              • Home of the Alamo
              Baking soda and super glue
              The following thread works great.
              John
              '81 XS1100H - "Enterprise"
                • 4015
                John- That thread had nothing to do with baking soda and super glue, lol. But, I heard that method has brittle results.
                • Bikes
                  • Oct 2014
                  • 174
                  • Coastal Maine
                  I came up with this method years ago when I was always fixing VW Rabbit dash faces.....
                  If its a clean break, super glue it together...then, cut a small section of a regular hose clamp, sized accordingly.....you know, with the slots in it for the screw to run on.....cut it long enough to span the break, maybe use in a couple spots depending on the length of the break....then, with a small torch,carefully heat the piece of clamp til nice and red, use needle nose pliers, have a small screwdriver ready, when its hot enough, lay it across the break, on the INSIDE of the piece, until the plastic ooozes through the slots, use the screwdriver to push it in and smooth out the plastic while its hot, you only have a few seconds. Once it cools and hardens, its not goin anywhere....
                  Hope this helps
                  Small pieces you can use bits of wire or old torch cleaning wires, bend little hooks in them for grip.....
                  I used this on my left cover where the locking tab broke....file it down to fit...works great...
                  Dont breathe the fumes, smoke from the plastic....you'll wind up like me.....
                  Mark
                  1980 xs1100g 3H5.......
                  1992 Ducati 907ie
                  2001 Moto Guzzi Jackal
                  • mrhammer2u
                    • Aug 2014
                    • 472
                    • Northern, NJ
                    My 2nd hobby is R/C cars. Lot's of banged up plastics. Check this out for a strong backing after you epoxy it together.
                    Rob - 79 SF
