I used the pine sol method and it worked wonders...the only issue I had with it is that if left in to long it eats away the enamel that covers them. This makes them rust pretty easy if your in a higher humidity area....my next time around I plan to put a light clear coat over them after they dry from a good soak!
Carb cleaning, just wondering
I'm looking for a way to clean my carbs without taking them off the bike. I ran across a video of a guy running his bike with SeaFoam in the tank, and then also - as the bike is running - adding Sea Foam directly to the carbs via a vacuum line. Stalled the bike of course but then he let it sit and stew in the Sea Foam for 15 minutes, started the bike and ran the Sea Foam out of the system. Anyone tried this before? If so, which line from/ to the carb should be used? Thanks.80 SGComment
I'm looking for a way to clean my carbs without taking them off the bike. I ran across a video of a guy running his bike with SeaFoam in the tank, and then also - as the bike is running - adding Sea Foam directly to the carbs via a vacuum line. Stalled the bike of course but then he let it sit and stew in the Sea Foam for 15 minutes, started the bike and ran the Sea Foam out of the system. Anyone tried this before? If so, which line from/ to the carb should be used? Thanks.. If you can really determine that carbs are the issue, they need to come off(no seperating bank necessary), dis-assembled and cleaned CORRECTLY. Sorry, there IS no lazy way around this and no magic wand waving, nor 'snake-oil' ideas is gonna resolve it for you
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Hey Jim,
SeaFoam is a good Maintenance product for after you have properly cleaned the carbs, but as Brant/Motoman stated, due to the intricacies of the circuits of these carbs, when they dirty/gummed up and such, there's no substitution for a proper tear down.
Take a look at this thread, I ran several carb bodies thru my metal cutting bandsaw to reveal the pathways in the carbs.
T.C.T. C. Gresham
I was refering to straight seafoam gas additive. I soaked my jets, emulsion tubes and other small parts for days with very little effect. If I get a real bad set of carbs, I'll strip them down to bare bodies and alternate between the ultrasonic cleaner and boiling water. Frankly the boiling is just as effective as pinesol, simple green, etc. and has no adverse effects like tarnishing, smell or cost.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
The thread on idle vacuum got me wandering around on the www and found this guy .His pdf treats (free) have comments on pods, ultrasonic cleaners ,dyna jetting, simplegreen and other stuff. I dunno.
79SF
XJ11
78EComment
http://www.oldschoolcarbs.com/general-info-pdf-files/
I think he's backwards on the idea that tight lash makes a 'lazy valve' though. Loose valve lash would do what he described but other than that he's pretty accurate and entertaining about Honda Keihin carburetors, maybe Hitachis too and only just a little off about Mikunis.
The Firefox open source commie-rat-barstool speel choker complained and suggested "Hibachis" and "Pistachios" for Hitachi but only has single word suggestions for the names of the other two carburetor manufacturers:
"Heineken" for Keihin and "Unionism" for Mikuni.
.-- Scott
♬Comment
