Side Cover Dampers
    • 2162
    Side Cover Dampers
    The rubber sleeves ("dampers") that go over the tab that interfaces with the slots in the top of my SF side covers have crumbled into nothingness.
    No longer available from the dealers.
    I bought dampers for other models (XS650, XS750), but none of them are close at all.
    I thought maybe my next move would be to try some of the thick PVC paint that us used to cover tool handles, toys, etc.
    Before I do that, I became sure that someone else on this forum has a great idea for this problem they haven't shared yet.
    That electrical tape just isn't doing the trick for me anymore.
  • Bergman16
    • Jun 2014
    • 286
    • New York, N.Y.
    Is it this part? 2H7-21717-00-00?
    Steve R
    '80 SG
    Former bikes:
    1978 XS400E Red
    1981 XS850 Special (Stingo)
      • 2162
      YES! That's the one.
        • 8083
        Mike's XS!
        Damper Rubber Metal side cover XS650 1978-80
        Damper Rubbers (Pk./2 for 1 sidecover) Fits: To 1" wide upper hanger for Metal side cover as used on XS650vSe/Sf/2F/G 1978-80. See web site model ID photo's of sidecovers if you are unsure of your sidecover type.
        Also fit DS7, R5, RD250, RD350
        OEM Reference Number
        2H7-21717-00, 466-21717-00, 466-21717-00-00
        • MPittma100
          • Aug 2011
          • 2359
          Grommets
          One or both of these should work:
          http://www.partzilla.com/parts/detai...717-01-00.html
          http://www.mikesxs.net/product/02-6501.html
          1981 XS1100H Venturer
          K&N Air Filter
          ACCT
          Custom Paint by Deitz
          Geezer Rectifier/Regulator
          Stebel Nautilus Horn
          EBC Front Rotors
          Limie Accent Moves On In 2015
          Mike
          • Bergman16
            • Jun 2014
            • 286
            • New York, N.Y.
            $12.98 at Speed and Sport using that part number.
            Steve R
            '80 SG
            Former bikes:
            1978 XS400E Red
              • 2162
              Thank Marty, Mike, and "Bergman".
              I'm pretty sure that Partzilla 360-21717-01-00 won't work- the XS11 is not listed, but the XS750s are listed. The XS750 are very different.
              That Mike's XS option looks like the ticket, from what I see so far.
                • 8938
                Another option, just remove the top ones altogether and bend the tabs slightly in for a snug fit.
                • Donmystic1
                  • Jun 2014
                  • 185
                  • Mystic, CT
                  Side panels
                  My wife says that I am Brain Dead.
                  I can't figure out how to unlatch the single bottom latch of the side panels that are part of this discussion.
                  78E, 79F, 80G
                    There is a key lock on the bottom and facing forward on the inside of the frame tube holding that Cover on.
                      and it has a black cover over the key slot making it difficult for the visually challenged ( read old guys) to see
                        • 2162
                        Left side only on my SF- protects the battery and tools from theft.
                        RH side just snaps in a grommet.
                        • mack
                          • 2411
                          • Ontario, Canada
                          Thrust Plate Grommet
                          You guys did such a good job on the side cover grommets, how about this. The rubber grommet that fits onto the nipple on the right side of the swing arm that the thrust bracket fits into. Anyone seen an aftermarket replacement?
                          mack
                          79 XS 1100 SF Special
                          HERMES
                          original owner
                          81 XS 1100 LH MNS
                          SPICA
                          78 XS 11E
                          IOTA
                          https://youtu.be/wB5Jfbp6SUc
                          https://youtu.be/RaI3WYHSuWA
                          Frankford, Ont, Canada
                          613-398-6186
                            • 8083
                            Yamaha 3H3-25374-00-00 SPACER,TORQ.STOP --- SPACER, TORQUE STOPPER, SPACER, TORQ.STOP
                            No. The XS650 uses a completely different rear brake set-up, so there's no similar part at Mike's XS. NW Vintage and Speed & Sport both show 0 stock on the oem number.
                            This part may deserve a new thread. Mine looks shabby, too. I put rubber lube on it every time I replace the rear wheel.
                            • mrhammer2u
                              • Aug 2014
                              • 472
                              • Northern, NJ
                              I bought the ones from Mikes XS and they fit well.
                              Rob - 79 SF
