Polished Slides
    • 4015
    Polished Slides
    There is a YouTube video of a '78 XS11 that was rebuilt to a beautiful status. The owner mentioned that he polished the slides to attribute to a quicker startup (almost instantaneous upon starter push). I mentioned this before, and it was stated that polishing the slides would have no effect on startup. Sounds fine to me
    On to my question: is there a specific lubricant/polish that is safe to use on the slides? I've used 3-1 oil before.
  • TomB
    • 967
    • Cumbria, UK
    Or are we talking Carb slides? Don't they have a clear coating on them from the factory? kinda non-stick finish. I wouldn't polish them or add a lubricant.
    Tom
      • 4015
      I believe they do, as I remember threads of the finish flaking-off.
        The slides have nothing to do with start up. If your carbs are right and battery good your bike will pop right over.
        • Yahman
          • Mar 2008
          • 779
          • Salem, OR
          This is just my seat of the pants observation. I have been adding a little 2 stroke oil to the fuel after I fill up. I don't always remember to add it. It seems to me that the carbs respond quicker with the oil added. My theory is that the slides are getting a slight bit of lubrication from the oil. I haven't noticed any other improvement.
          Ride safe,
          Larry
          82 XJ1100
          80 XS1100G (Project bike)
          64 Yamaha YA-6
          77 Suzuki TS-185
            Ride safe,
            Larry
            The 2-stroke oil in the fuel is just makes for an octane booster for the fuel......approx. 4RAN points.
            • James England
              • 3039
              • North of England
              Mmmm...any bikes I've done always start immediately on the button.....without carb slide polishing. I can't imagine it makes any difference at all.
              • Gmac
                • Aug 2014
                • 256
                • Huntsville, AL.
                It sounds like
                voodoo science, carb slides will be bottomed out on startup and not enough airflow to make them move.
                I have always used Marvel Mystery Oil in all my motors ever since my grandfather showed me. I buy the big red bottle and dump half of it in when I fill up the car, ~12 - 13 gallons. Grandpa called it 'top oil' and said it was good for the valves.
                79 SF & 80 LG MNS
                73 & 74 RD 350's
                73 Honda CL 450
                Graveyard - '81 XS850 Special
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  +1 Grandad !
                  I use MMO in the fuel, about 1 oz. per gal., good stuff !
                  But I filled one set of carbs thinking it would protect them, the mess I found when I went to drain them was not fun. The MMO had sucked all the junk out of the bowls and it was just a grey goo ? ? ?
                  76 XS650 C ROADSTER
                  80 XS650 G Special II
                  https://ibb.co/album/icbGgF
                  80 XS 1100 SG
                  81 XS 1100LH/SH DARKHORSE
                  https://tinyurl.com/k6nzvtw
                  AKA; Don'e, UD, Unca Don'e
