XS11 SH rebuild status - It started
    • 8962
    Originally posted by RichV
    I ordered the Pingel 9050-AV cutoff to replace the function. I don't want this to happen again.
    I run one of these, it is advisable to put a restrictor in the vacuum line to keep the unit from pulsating which will shorten it's life, DAMHIK. Pingel will rebuild them for $22 if needed.
    • RichV
      • May 2013
      • 374
      • Everywhere
      Thanks. That's a good idea.
      _________________________________________
      1981 XS1100SH (Lola) - Bright Cardinal Red
      Whatever Lola wants, Lola gets.. Don't mess with Lola.
      Mostly stock with a few minor upgrades
      1981 XS11000SH being used for parts (Sold off)
      Also have:
      2009 Harley Davidson FLSTC with over 120K miles. All mine.
      Currently traveling the country with an aluminum can in tow and a motorcycle in the truck bed in search of the perfect road.
      • Eveready1100
        • 539
        • Childers, Queensland,Australia
        Just a note of caution regarding fitting a restrictor to the vacuum lines of the fuel taps. Have a read of post #2423 by Tom about what happened to his motor at high speed where the vacuum tails off - CLICK
        • RichV
          • May 2013
          • 374
          • Everywhere
          I doubt I will ever get to those speeds (well maybe once). It's more important that this bike operate well at lower speeds. My plan is to go without at first and then add later.
          Also have:
          • RichV
            • May 2013
            • 374
            • Everywhere
            I mounted the Pingel and it works fine. However, it did not solve the problem with the fuel leak.
            I removed the carbs (again) and checked the floats. #2 was stuck. Since I had it open anyway, I rebuilt the carbs using this kit.
            It fit great and the carbs are re-installed. No leaks. Engine started the first time.
            Also have:
            • wjw11teen
              • Mar 2014
              • 93
              • Valleysprings.S.DAK
              I have an 81 special and went through the same situation....I used q tips cut in half..the stick kind are best but not absolute..i put a little polishing compound on the tip,chucked the q tips in a drill and polished the seat area till it shined like a new penny on all 4 carbs...no more sticky needle valve issues...the compound cleans up easy with a few steady shots of carb cleaner through the fuel supply rails..then some good shots with the compressor and re assemble...
              81 SH gifted to SON
              • MPittma100
                • Aug 2011
                • 2359
                Fuel in Oil
                Make sure to check that no fuel got into the oil while carb was leaking. This easily happens as the cylinders are downhill from the carbs. Good idea to put a 2X4 under the front tire when bike sits for long periods. This will prevent any leaking fuel from going into the cylinders/crankcase.
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
