Just cecked out Partsnmore and they don't have SINGLE REAR DISC BRAKE CALIPER REBUILD KITSFits front & rear: XS1100 E/F/G/H (78-81). I put new S/S brake lines on a weak caliper piston seal (Square O-ring) knew I shouldn't do it but got exited when the lines came in from Randy (AKA "The Swamp Thing") they just looked so damn good I couldn't wait. All lines held 14lbs pressure on MitiVac, thought I must of been wrong about O-ring. Had a cage driver that decided it was easier to back up the freeway exit ramp than to keep going thru a traffic light and back on freeway, (a total of about 45 seconds of his life) the correct way. Anyway I had to lock them up HARDDDDDD, I hit them like I used to have too. Ok bad idea, I mean I stopped on a dime with change. Gotta relearn how to ride with the new lines. Anyway does anybody out there have a good square O-Ring they can part with. Left front is leaking bad and now I can't bleed as when fluid comes out around it, air comes back in. Also mess's up my pretty caliper. and soaks the pads.
Oh yeh if you want to see the lines go to http://www.imagestation.com/album/?id=4286970403
