petcock ?
  • mrhammer2u
    • Aug 2014
    • 472
    • Northern, NJ
    petcock ?
    I'm buying a 79 xs. Have not seen it yet but pretty done deal. Just needs a tank. Found an 80 tank on ebay but it looks like it only has a spot for 1 petcock.
    Are there some tanks or bikes that only came with 1 petcock? Or maybe I'm not seeing the picture well enough.
    Thanks
    Rob - 79 SF
    750-850's have only one petcock IIRC and the tunnel on the tank itself too narrow to fit the 11's frame. Possible that someone eliminated one of the taps, that is what I did on both my 11's.
    • Eastcoaster
      • Jan 2012
      • 513
      • oceancity NJ
      If that's the Baltimore Bike you could cream the tank it sounds like only a few pinholes on the seam. Not the best but do it right it can last a long time I used red coat still going fine
      82 XJ1100J
      81 Venturer
      • mrhammer2u
        • Aug 2014
        • 472
        • Northern, NJ
        Not a Balt bike. PA. Just wanna get a tank on it asap so I can make sure it fired up and runs....as claimed.
        Rob - 79 SF
        • Eastcoaster
          • Jan 2012
          • 513
          • oceancity NJ
          There was a 79 in Baltimore I thought that might be it I work in Phila if it is near and you want eyes on it let me know
          82 XJ1100J
          81 Venturer
          • mrhammer2u
            • Aug 2014
            • 472
            • Northern, NJ
            Much Thanks. It's in Scranton which is pretty far from ya. Otherwise I'd take you up on it. Plan on going out soon as this storm passes.
            Rob - 79 SF
              • 4015
              Nope, double petcocks on both bikes. Think of the 750/850's as the 11, with a cylinder missing. A few other differences like mechanical tach, no vacuum advance, CCT in the rear of the engine, etc.
                Thanks Ian, I stand corrected. Will the tanks interchange though?
                  I have an XS750 tank in my inventory. An XS750 tank will not fit an XS1100. I expect an XS850 tank is very unlikely to fit.
                    • 4015
                    The seat anchor would not line-up.
