MNS History
  • MPittma100
    • Aug 2011
    • 2359
    MNS History
    Was the MNS produced in the US only or in other countries as well?
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    I'm not positive, but I believe all Specials were for North America only. I haven't seen evidence to the contrary, other than the occasional Special that turns up overseas.
    • mack
      • 2411
      • Ontario, Canada
      Mns
      I know of two in England for sure. And Fastred1 also has a 79SF.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
        • 4015
        I believe James has said that Specials were US only. However, their RH model is close to a Special I believe.
          RH doesn't share much with a Special. The tank is so obvious, but it's a trick. The rear wheel is 17" and the frame is different than the Special.
            The RH is the closest thing to an MNS or Special that Europe got.
              Yes, it shares the tank and little else. Same for Oceana, Greg?
                Don't know anything about that.
                • TomB
                  • 967
                  • Cumbria, UK
                  Europe didn't get the RH, we got the S, frame + engine designated the 5K7.
                  The RH was Oceana, Oz, NZ, Japan home market etc
                  I only mention it coz this thread is model specific. The 5K7 and RH are VERY similar but there are slight differences, if the two were parked next to each other you wouldn't spot the differences unless someone pointed them out.
                  Yes the RH and S appear to be a slightly altered MNS but have subtle differences, even little detail changes like the neutral light pod is different to the MNS/Specials.
                  Tom
